Question about Garden
My PTO will not run in 540 or 100 it only works in drive mode.
Engine runs, but when I engage the electric PTO why does it go dead?
Newer mowers have a safety interlock that prevents the mower running when going in reverse. My guess is that the reverse switch is on and when the PTO is activated the engine dies like you shut off the key.
Second idea is that the device the PTO drives is frozen up. Test this by trying to see if it turns with the engine off. When you engage the PTO the engine chokes down because it can't turn the PTO.
Mar 29, 2016 | Garden
Why doesn't my Toro z master PTO not engage
check to see if pto will engage if not check voltage at pto if non blown fuse if fuse not blown and power to pto bad pto jump the pto at pto with battery in mower does it start pto if does good pto have to check volts at switch check there start with that let me no what happened
Sep 04, 2014 | Toro 60'' Com Zero Turn Lawn Mower 27hp...
What does PTO stand for
power take off which drives the belt that runs the mower deck sounds like a dead short in the pto clutch maybe a wire shorting out check for bare wires
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
Clutch for johndeere 870
That is normal for a live pto. If your tractor has a two stage clutch you should be able to stop the PTO with clutch all the way in (as in push the pedal all the way down). It should be transmission independant, meaning it will work even though the transmission is not turning AND if you are running something that has a lot of inertia, it won't push you around by driving the rear wheels even though you have the clutch in.
Aug 25, 2012 | John Deere 760 790 850 870 Flail Spreader...
I have a j d 430 lawn & gargen tractor. can't get it to move is there any levers other than the one on the dash that i need to engage to get in to move? it runs fine the pto works the lawn deck...
I have a Craftsman and there is a pull out rod in back that disengages the drive so you can push the mower, if necessary. If you can push it this rod must be out of the drive mode. If you can't push it, it is in the drive mode.
Gary
Jun 22, 2011 | Garden
I need a belt diagram for a ranch king king plus also i need to know the size for the main drive belt
Ranch King is a brand name of the manufacturer MTD.
Product manuals with part blow-up diagrams are available from MTD's web site,
http://www.mtdproducts.com/
Models are identified from the model number printed on a label under the mower seat.
The PTO and deck drive belts are shown on one diagram and the transmission drive belt is shown on another. The Form number on my printed Operator's Manual is 770-10526A (22HP, 46in cut) for Hydrostatic 817/818 models.
Parts can be ordered directly from MTD or other distributors on the web.
It is my experience that original brand name MTD belts work best.
The 22HP, 46" mower deck Ranch King Pro has 3 belts:
The drive belt which runs from the engine pulley back to the hydro drive unit to provide over-the-ground propulsion is part #754-0349.
A mower has either an electric PTO or a manual PTO, not both.
The electric PTO belt the provides power to the blade deck (runs around the electric clutch on the engine shaft (activated by electric switch, not the mechanical hand lever that engages the mower deck) is p/n 754-0476 for the 46" deck.
The manual PTO belt the provides power to the blade deck (runs off the pulley on the engine shaft (activated the mechanical hand lever to the left of the steering wheel that engages the mower deck) is p/n 754-0228 for the 46" deck.
The deck belt that goes around the 3 blade spindle assemblies on the mower deck, to drive the grass cutting blades is p/n 754-0349
In my experience, the PTO belt lasts about half a season, the other belts break about every other season when mowing 4 acres weekly.
Sep 07, 2009 | Mtd Garden
Garden Logo
15 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
