Question about Garden
Manual for magna rear tiller model 500460
Magna america
SOURCE:
stormbrewin
  • 426 Answers
SOURCE: help with my mitsubishi magna 1994
Could be a few things.If you check radiator fan and its ok move down to the thermal power switch usualy at the bottom of the radiator.Make sure you have power in and out of the swich when the engine is at operating temp.Use a test light/probe easy to use and cheap to buy.If the switch is ok the next step is the relay in the box with lid next to the battery.Sometimes just pulling the relay out and putting back in will fix the problem due to poor contact.To sum up its usualy the thermal temp switch but check every thing else before wasting money on the wrong things.Good luck
Posted on Nov 08, 2008
salvidordali
  • 103 Answers
SOURCE: magna vibration when accelerating
I'm just guessing but i would say you have a bad engine mount.
Posted on Jan 10, 2009
SOURCE: Carb removal from 1994 VF750C Honda Magna
You should probably get a service manual.
As I recall: Remove seat, gas tank, side covers and brackets, and plastic things in front corners of frame. Take off rubber intake thingy and slide out air filter cover toward the left side (it's a ***** because of the flap in front). Loosen metal intake housing plate, rotate and remove intake horns being careful not to bend the horns or drop screws down carb throats. Slide plate out.
All four carbs come off as one assembly. There are four rubber tubes connecting it to the engine. Loosen the hose clamps on the tubes and gently pry the carb assembly up. Find safe points on the carbs to pry where you won't break anything, and be gentle. If it hasn't come off before it will take some going from corner to corner till it comes out of the rubber tubes.
You can clean the jets without disassembling the "quad pack".
I put a little oil on the tubes to reassemble. Getting the horns back in is a bit tricky. The plate goes on loose, then they slide into the carbs and rotate as I recall. Good luck
Posted on Jun 21, 2009
  • 13 Answers
SOURCE: Can't find the transmission drain plug?
m8 there is no drain plug for auto or manual on the box. you have to completely take the pan off, clean it, put new gasket and silicone
Posted on Aug 09, 2009
SOURCE: Remove manual V6 Magna trans from motor
undo all the bolts connecting transmission to tail shaft, then do the same with all the bolts connecting transmission to motor take out transmission.
Posted on Dec 30, 2009
Honda Magna V65 how to replace the rear tire
Hi, Timothy for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can't find the best tool you ever bought for your Kawasaki, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda magna rear tire removal and assembly V4MuscleBike com http://www.magnaownersoftexas.com/forums/index.php?topic=1355.0
how to replace the rear tire on motorcycle Google Search
Honda V65 MAGNA Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
http://v4musclebike.com/articles/v65OwnersManual.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 13, 2018 | Honda Motorcycles
2002 Honda VF 750 C Magna brake and running lights not working
Hi, Rredondo64 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rear Running Light Problems
rredondo64 Honda 2002 Magna with no Brake light or running lights 2002...
Honda Magna VF750C Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda 1995 VF750C Magna Owner Manual
Jun 16, 2014 | 2002 Honda VF 750 C Magna
1985 Honda VF 1100 C head bolt torque specs
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda 83 86 V65 Official Shop Manual pdf
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Honda VF 1100C Magna V65 Make Model Honda VF 1100C Magna V65 Year 1985 86...
Honda Magna Wikipedia
Apr 21, 2013 | 1985 Honda VF 1100 C
1995 Honda VF 750 C Magna rear sprocket torque specs
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Drive chain adjustment lubrication
Motorcycle Chain and Sprocket Replacement
Nov 03, 2012 | 1995 Honda VF 750 C Magna
Hello to every one! I'd like someone to send me the manual for the Honda Magna Vt 250 Magna, model of 1996. Thank you for your time. Mike
You can either visit your local Honda dealer or order a workshop service repair manual online from Clymner.com.
Oct 06, 2012 | Honda VT 250 F Motorcycles
How to replace the rear chain on a Honda Magna
Chain and Sprocket Replacement Honda Magna VF750C
Sprockets and Chain Installation on Honda Magna
Sep 01, 2012 | Honda VF 750 C Magna Motorcycles
1985 V65 Magna hard backing up on level ground
Hi, Rwein5498 the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
Apr 13, 2012 | 1985 Honda VF 1100 C
What is the weight & amount of fork oil for a Honda VF750 magna 1993 model?
Hi, Hm1200 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
How Much Fork Oil
https://www.louis.eu/rund-ums-motorrad/bike-datenbank/honda-vf-750-c-magna/rc43/0315
Nov 22, 2010 | 1993 Honda VF 750 C Magna
How to change air filter on honda 750 magna 1995 model
Hi, Mbboboian for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Replace Air Filter
1996 Honda Magna Carb removal flv
Oct 18, 2010 | 1995 Honda VF 750 C Magna
Adjust preload rear shocks for 160lb rider on 1998 honda magna
Hi, Mafroze for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Rear shock spring preload adjustment
How to adjust rear shock
Sep 30, 2009 | 1998 Honda VF 750 C Magna
Garden Logo
15 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
