Question about HQRP 20A Solar Panel Battery Charge Controller / Regulator 12V / 2
How low can I safely and repeatedly discharge the THUNDERBOLT MAGNUM SOLAR 12 Volt, 35 Amp Hour Universal Battery?
I have read blogs that say 50% although that varies but most often I see down to 11.9volts only which is not near the 6.5 Volts which I was expecting due to the rating of AGM batteries saying 50% was acceptable.
Which is the best freight software providing company?
Info-X Software Technology Pvt. Ltd. is one most trusted and reliable freight software providing company that manages all your business logistics with the help of their proven freight rate management software. Their back office manage all your contract rates with their dedicated resources. Freight rates are shown with breakdown of ocean freight and surcharges. Overseas surcharges can be displayed in foreign currency. See more at
15 YEARS OF BACK OFFICE EXPERTISE IN
Nov 16, 2015 | harbor freight tools THUNDERBOLT MAGNUM...
How to change batteries
Size U1 gel or SLA (Sealed Lead Acid). 12 volt 32-35 Amp Hour.
Best brands are MK, PowerSonic, Panasonic, Universal UB12350, and FIAMM.
Aug 07, 2014 | Pride Mobility Jet3 Batteries
Using solar panel to power small appliance
If you guys want a free way to get your electric and natural gas supply for free in PA,NJ,CT,NH,ME,RI,NY,MD,OH,ILGA.,Texas .Get you Energy company to pay you every month too. Call me : leave a message I will get back to you ASAP .i will be happy to help .People helping people .Scott at 267-549-3746.
Mar 31, 2014 | harbor freight tools THUNDERBOLT MAGNUM...
Can a 33amp hour battery be used in a mpv5hoveround
If it is a 12 volt Size U1 - yes. (UB12350, GPC1234, GPL-U1, NP33-12B)
The amp hour rating is dependent on use and manufacturer of the battery. It is the size and voltage that matters. AGM batteries generally have a slightly lower AH rating but recover better from deep deep discharging cycles. (Available at marine stores)
The amp-hour rating affects how long the chair will travel between chargings.
Feb 26, 2014 | NRS Health & Beauty
I just received my Thunderbolt Magnum Charger that I had ordered from Harbor Freight Tools. I plugged it into my 2012 Nissan Rogue to try it out and it turned on my car's radio. I assumed this was not a...
This charger is a maintenance charger and will not have enough power to charge a dead battery. It is used to trickle charge a battery to keep it charged and to off set any parasitic drain.
Feb 17, 2014 | harbor freight tools THUNDERBOLT MAGNUM...
I have a Hayward Power-Flo LX SP1515-Z2-EBK3 that is being used to pump water through 2-4x8 solar water heater panels. The pump intake is 1 1/2 inch, discharge out is also 1 1/2 inch. The pump is located...
I have a 3/4 hp hayward pumping thru solar panels, too. 1-1/2 discharge thru 50 ft of 2inch pipe, up 12 ft then thru (4) 4x12 panels. Mine is on 115 volts ac.
You have plenty of pump and when you run a pump with low flow, amperage is low. You are not tripping your breakers, it sounds like the pump is overheating. Is it hot to the touch when it shuts down?
Do you have an ammeter so you could check your amps?
What size wire is running the 60 ft to the pump?
I don't have any other ideas to share.
Gary
Sep 06, 2011 | Hayward Power Flo Lx
I had my wheel chair in storage for about an year, I have attempted to charge but when I disconnect the joy stick blinks yellow for low battery...How do I determine if both batteries are bad? If so do I...
Hi.Sounds like your batteries have sulphated plates, this happens when they sit for too long without being used. Your machine is a 24 volt system, so it needs both batteries to be working.You might be able to get a bit more life out of the batteries.
Try removing both batteries from the machine and connecting a light bulb across each battery and discharging them until they are flat.
Then using a 12 volt charger, ( not the charger for the machine, which is a 24 volt charger ), charge the 2 batteries in parallel. Sometimes it helps to charge them up the wrong way for a few hours, then discharge them again with the light bulbs. After this charge them again in parallel with the 12 volt charger, this time the correct polarity, a leave on charge for 12 hours.
You might have to repeat the charge, discharge cycle a few times.
The batteries will accept a charge after a bit of this, but they might not be as good as new batteries.
If you are unsure how to do this, get some help from someone who can do the work safely.
Good luck. Neil.
Jul 27, 2011 | Invacare Pronto M51 Power Wheelchair
Harley davidson batteries are they 6 or 12 volt?
Hello, my name is Ben. Your battery is 12 volts. Here are the complete battery specs : 12-volt, 19 amp-hour, 270 cca.
Oct 11, 2010 | 2001 Harley Davidson FXST Softail Standard
Wont take a charge
You need a new battery, their life is around 5 years, or if you leave them discharged for a while they start to loose capabilty to hold charge.
Jan 03, 2010 | Yuasa (Enersys) Genesis NP4-12 - 12 Volt/4...
HQRP 20A Solar Panel Battery Charge Controller / Regulator 12V / 2 Logo
14 people viewed this question
Top HQRP Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a HQRP Office Equipment and Supply Expert? Answer questions, earn points and help others
