SOURCE: ZyXEL P-660HW-D3 password change
There should be a tiny recessed 'button' (usually more of a hole) in the back of your router. This may be marked 'reset'.
To use this to reset your router, the manual for the Zyxel P660HW router advises that your power LED should be on, but not blinking.
Push the end of an opened out paperclip into the 'reset' button (hole) for 10 seconds, or until the power LED blinks. This restores your defaults. The manual I have advises that your password will be reset to 1234. If you have a manual, please check this.
Good luck ;-)
SOURCE: how to bring back the router function of zyxel P600 w/o password
You can simply reset the device to factory defaults. There's a reset button at the back of it. Hold it down for 30 second with the power on. That will reset the unit back to router function.
SOURCE: Iphone will not accept Password in Zyxel Router
this problem was on g1 iphone, it is solved whith the OS3.01. the 3G iphone is working good....but the 3G S have a different chipset (with FM) and seems not working again... the login is ok but he swich back to 3G and dont stay on wifi.
SOURCE: even after doing a hard reset on a zyxel eq-660r
Go to the manufacturer's webpage - the password may be incorrect for your router. Try another hard reset if the password is confirmed; software is fallible (just look at computers!).
