Question about Monster SC20 1200 Pressurized Steam Cleaning and Sanitizing System
How do i order replacement boiler cap for monster 1200 sc20
Water is coming from the cap of my monster 1200do i need another cap
Fixya cannot supply a replacement Monster cap.
Jan 22, 2018 | Motorcycles
I need the Monster 1200 Manual
Do a web search for the manufacturer and model and usually they will have this information available for download there.
Oct 05, 2014 | Euro-Flex Monster 1200 Handheld Steam...
Refill water tank
With the unit unplugged push down the steam lever and hold while pushing down and turning the cap..
Dec 25, 2013 | Euro-Flex Monster 1200 Handheld Steam...
I can not get my Ducati to run it has just been sitting
Hi, Mnskaterdude if your bike has been sitting idle for months or years and you did not do any pre-storage maintenance I feel your pain it will probably have a dead battery and not want to start or if it starts it will idle and run poorly, here are the following steps necessary to complete in order to get your bike back to an acceptable running condition.
1. If your battery was 3 years or older when you last had the bike running you should replace it.
2. If you believe your battery might still be serviceable remove it from the bike and put it on a 1 or 2 amp trickle charger for 24 hours. If it is the old lead acid type with visible cells and acid levels fill each cell to the top line with distilled water and replace the caps, run the vent tube into a plastic or styrofoam cup, any cells that are cloudy/milky replace the battery.
3. After charging remove the leads and let the battery sit for a couple of hours then check the battery voltage with a volt meter, you should have 12.5 volts or better, any readings in the 11 volt range you need to do a proper load test on the battery and replace as necessary, any readings in the 10 volt range you have a dead cell and replace the battery.
4. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
5. Remove your air cleaner and clean and re-oil per Mfg. specifications.
6. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
7. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
8. Replace spark plug with a new one and check for spark.
For more information about your issue and valuable free downloads that you will need please visit the websites below.com. Good luck and have a nice day.
http://www.ducatimonster.org/forums/general-monster-forum/291129-2001-m600-repair-custom-paint-job.html
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Ducati Monster 600 Monster 600 Dark Monster 600 City Monster 600 Metallic...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 04, 2011 | 1999 Ducati Monster 600 - Dark - City -...
Cannot remove cap that is used to fill monster steamer cleaner
Press the Water tank cap and Unscrew it to the empty water tank. (Page 7)
Manual is at the link below.
LINK
Hope I was help.
Mar 28, 2011 | Euro-Flex Monster 1200 Handheld Steam...
Replacement of the boiler cap
Hi Gilbert,
Krups still sell some parts for this model.
If you still looking for the boiler cap I think you can find it here:
http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+MS-0907815&MENU=parts&SELECT=espressomachines&SKW=PARTF872
Dec 21, 2008 | Krups Bravo Plus 872 Espresso Machine
Monster SC20 1200 Pressurized Steam Cleaning and Sanitizing System Logo
Top Monster Garden Experts
roeb
john h
Marvin
Marvin
Are you a Monster Garden Expert? Answer questions, earn points and help others
