SOURCE: Sony DSC-P93 battery replacement question
NiMH batteries. You can use the larger mAh AA. It has more capacity and should give you longer service before needing recharge. The battery manufacturers recommend that you do not mix the batteries. i.e. don't use mAh 2100 and mAh 2500 as one set, use all 2100 or all 2500 as one set.
SOURCE: how do you change the bulb in a minimaglite
1. Unscrew the "bell" (top) of the flashlite. 2. Remove the bulb by pulling upward. 3. Replace with new bulb (be sure you have the correct bulb . . . it will have two small wires protruding from the bottom). 4. CAREFULLY insert new bulb through hole in the bottom of the reflector. 5. Screw the top of the flashlight back on.
SOURCE: 2005 touareg driver side headlight assembly
I'm not sure you will find a lens. The headlights are sealed units. I would check ebay.
SOURCE: Can't find replacement light bulb:refrigerator model ET18DKXWW00.
Your problem may be in the bulb receptacle or the light switch.
If you have a voltmeter, let me know and I will tell you how to check it.
SOURCE: battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
