Question about McCulloch Electrical Supplies
Were can I find a low oil sensor for my mcculloch 5700 generator
SOURCE:
Loringh
  • 185 Answers
SOURCE: Won't start.
Hi raw 28:
ther gas that was in the carb probably evaporated. you might tryt a little spray starter fluid in the spark plug hole or in the air intake of the carb, This might just get it running long enough to draw gas into the carb and get it self sustaining,
Good luck Loringh
Posted on Dec 02, 2008
mamicheddy
  • 79 Answers
SOURCE: McCulloch fg6000mk: generator motor runs, no power.
You need to trace out the power wires the come out of the genset. They will end up on a breaker. With a volt meter measure both sides of the breaker. If one side has voltage and the other side doesn't, then your breaker is opened. Press the breaker in closed to see if it actually closes. If it don't then you will need a breaker. However, if no voltage is being produced, it is possible that the voltage regulator let go.
Posted on May 09, 2009
  • 23 Answers
SOURCE: shorted out generator??
they do smoke if its petrol lol joke sounds like a short circuit check the connections
Posted on Jun 08, 2009
  • 630 Answers
SOURCE: low oil switch cut engine off and on when cold
It is not the oil switch you need to adjust the heads open the side and check on the settings for both in and out and adjust them according to the manual...in the winter sometimes they do not like heavy oil so check the oil weight and try lighter one
Posted on Nov 07, 2009
ROMOAS
  • 97 Answers
SOURCE: I have 5700 Mcculloch generator and when I open
remove the filter and look down the tube if the carb is filling with fuel then the float needs adjustment or replaced from sinking the tube if it is the one that attaches to the side of a plate on the engine block then replace the oil do to your filling the case with gas this ia is vent tube that attaches from the plate to the carb just under the filter you may have to rebuild the carb about $20.00 for the kit and $6.00 for a float. hope this helps
Posted on Aug 31, 2010
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
What oil does it use
Give us a call when you are with the Generator and we will run through it with you. Call your local office and speak to an engineer: http://www.generatorguru.com/ask-the-guru/
Generator Guru
Aug 24, 2015 | McCulloch 11 HP 5700 WATT GENERATOR
Low voltage
You have overloaded the generator and have blown a capacitor, resistor or similar item that will only allow half the voltage output to the recepticals. I know I have done this too.
Dec 05, 2013 | McCulloch 11 HP 5700 WATT GENERATOR
Where can I buy a mcculloch 5700 generator carburator
if you can not find a carburator you may need to find a re-built kit on the internet.
Aug 28, 2012 | McCulloch 11 HP 5700 WATT GENERATOR
I need a spark plug for a 5700 watt 11 hp generator, which one do I need?
Hi and welcome to FixYa. I am Kelly.
The standard plug is an NGK "BPR5ES" or Denso "W16EPR-U" There are a number of alternate plugs out there if you use the number above in a cross reference book.
One thing to note... the generator has a "Low Oil" sensor and if the oil level is low you will not see any spark. If after you install a new plug and you still do not have spark... un-hook one wire from the low oil level sensor and check spark again. If you unhook the sensor wire knowing full well the oil level is full.and have spark; the sensor is either dirty or bad.
Thanks for choosing FixYa,
Kelly
Feb 19, 2011 | McCulloch 13HP 338 Cc Portable Generator #...
We have a McCulloch 2300 Generator. It runs, but no electrical output. What should I look for ? Glenn
look for a reset button, either on the generator or on the dash with the recepticals. my 5700 has fuses there also
Jan 03, 2011 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Jul 22, 2010 | McCulloch FG6000MK 5700Watt 13 HP 338CC...
Wht weight oil does a 5700 take?
allot the generators take 30 weight but thats a guss in the winter i had go with light weight.
i am on my second colman i lived woods for years with no electrci other generator 30 weight is heavy stops less wear tear on the insides. But winter time comes i had go lighter becuse oil was like malassas. And then i could not pull it to start it was so thick and heavy the oil in winter
go there web site look up ore try 1800 number for them to get
Jul 28, 2009 | Electrical Supplies
Shorted out generator??
Jun 08, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
26 people viewed this question
Top McCulloch Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Mike
Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
