Question about LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television
White spot.. One of my kids throwed at toy at the tv and a small piece of plastic came loose from the screen. When it fall off a small white spot was visable under it. Can i fix it??
  • LG Master
  • 5,138 Answers
Yes, if you order NEW screen starting price 500.00 .
Posted on Aug 09, 2009
6ya staff
SOURCE:
Rear sliding door will not open
You have failed to mention, does it at least "unlatch". Do hear the mechanism come free from the locking post? The Caravan, & the Voyager, Ibought & maintained for my step-daughter,both developed similar isues. My grand kids, unfortunately are sloppy kids. The channel (guide) that the dooor roller rides in, faces up, not concealed underneath, or covered by a cover. Any loose frendh fries from a fast food joint, or small pieces of kids toys, dirt & rocks from Little League shoes easily find there way into that track. Is that track clogged with debris??
Sep 05, 2011 | 2000 Plymouth Voyager
My Htc Touch pro screen, looks like it has a large wet spot in the middle, i know for a fact it hasn't been near water, my screen is totally visable but not able to use by touching the screen, what could...
I suggest taking it to your compaany store but before you go to the store and have them tell u the phone is water damaged, you can save yourself the trip by looking for yourself. There should be a little square located in the back of you phone right below the battery and a little square locatedd on the batery where it connects to the phone. If the phone has water damage then the littl e squares should be red if they dont have water damage, the squares should be white with a plaid kind of design.
Jun 17, 2009 | HTC Touch Pro Smartphone
RU -44, small "pink" spot on screen.
Green is missing from the area where you see the pink (actually magenta) spot. This might be due to a large amount of dirt on the green lens. It may be due to damage to the face of the green picture tube. You need to remove the front screen so you can look into the lens and determine that.
Depending on the make and model of TV, the screen may be held on by snap fasteners and come loose when you pull on the plastic bezel surrounding it. Or the bezel may pull off to reveal brackets screwed into the cabinet that secure the screen. Or there may be a trim strip under the screen that pulls off to reveal screws. Remove those and the screen will swing up and off.
Once you can see the lenses, clean them with a soft rag and glass cleaner. With the set on, look down into the lens and you can see the face of the picture tube. If you see a dark spot on the face, the tube is damaged and would need to be replaced
Apr 22, 2009 | LG RU-44SZ61 44" Rear Projection...
HOW DO YOU KEEP THE TELEPHONE HANDPIECE FROM FALLING OFF OF THE WALL ? THERE IS NOTHING TO HOLD IT IN A VERTICAL POSITION. THE MODEL NUMBER IS EM 2646.
Under where the headpiece hooks on, there is a very small white piece of plastic about 3mmby4mm and it slides out if you pull it up and if you turn it upside down and slide it in a plastic piece sticks out and the phone will hook on to it. It is dezined to be both desk and wall mountable. Email me Chris at chrsstreeks28@gmail.com if you have any more questions.
Mar 24, 2009 | Emerson EMSEM2646WH Phone
Printer makes a loud clicking noise
Same problem after a paper trapped. I don´t know if the paper trap was because something broke, but after I took the paper the noise started. Please someone give us a solution.
Apr 13, 2008 | Samsung ML 2010 Laser Printer
LG RU-52SZ51D 52" Rear Projection HDTV-Ready Television Logo
Ekse
RONALD CARTER JR
