Question about Garden
Is smart choke the same as vacuum choke on Kohler149 cc engine engine on LawnBoy mower will not start, seems to be leaking fuel around filter . have cleaned carburetor
SOURCE:
#1 Taper
  • 1041 Answers
SOURCE: Engine only runs with choke full on. Dies when off full choke.
Hi Dave, it sounds crazy, but try this. Check your gas cap. It could be clogged, causing a vacuum to occur in the tank, and therefore not allowing the carb. to take on gas. It usually take 10-15 min. for this to occur. The next time you run the mower and it starts to stall out, loosen the gas cap and see if it begins to run again. If it does, then you know that the gas cap is clogged.
Jim
Posted on Jun 05, 2009
woobie dog
  • 1273 Answers
SOURCE: My LawnBoy mower 195 cc 4 cycle that starts fine.
It sounds as though it is starved for fuel. Check the pinhole vent in the fuel filler cap. if it is plugged, the engine will still draw fuel, until a vacuum is pulled on the tank, resulting in no fuel. If this doesn't fix you. check for adequate fuel at the carb, and wirk either forward or backwards from that point, depending on what you find. I'm betting on the vent!
Try it; it may be just the thing!
Best regards, --W/D-- please feel free to rate this solution! Thanx!
Posted on Jul 30, 2009
  • 10865 Answers
SOURCE: Honda 160cc mower engine starts and dies.
Your carbeurator is crudded up. Get a can of aerosol carbeurator cleaner at any auto parts store. Remove the air filter and spray two squirts of cleaner into the air intake. Start the engine and keep it running by squirting more carb. cleaner into the air intake. WIth a little patience you will clean your carb. and solve your problem.
Posted on Sep 14, 2009
mickey813
  • 472 Answers
SOURCE: rough low throttle on Lawnboy Dura Force Pro 6.5
IT HAS A WEAK SPRING THATS ALL IT IS
Posted on Sep 30, 2009
SOURCE: 10 year-old lawn mower Craftman Eagle 1, 6.5 horse
sounds like the main jet is blocked. remove it and run a piece of fine wire through it and retest.
Posted on Nov 28, 2010
Hard starting craftsman riding 24 hp mower
If your fuel filter has no fuel perhaps you have a leak or loose gas fitting . try tighten all gas fittings from gas tank to carb.
If the gas tank is higher then the engine then it may be gravity fed (no fuel pump).If you do have a fuel pump the make sure it's in working order. Make sure there's no blockage in your fuel line.
Oct 03, 2016 | Craftsman Garden
Lawnboy mower model 10743 will not start
When choke not on all the way coil willnot activate and throw spark ps carby should be cleaned out properly because fuel will off evaporated leaving oil guming up needle/seat
Jul 03, 2016 | Garden
Have Lawnboy Kohler 149cc smart choke 6.5ft lbs engine bought last year won't start doesn't seem to be firing?
REMOVE THE SPARK PLUG, RECONNECT THE CABLE AND WHILE THE SPARK PLUG IS RESTING ON THE BLOC OPERATE THE STARTING PROCEDURE AND SEE IF THE PLUG IS SPARKING.
May 09, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Lawnboy Commercial Mower - idle speed adjustment
did you have the governor arm off of the motor
Jun 06, 2013 | Garden
Briggs and Stratton
clogged fuel line. the choke restricts air flow if it runs fine choked it is probably getting too much air to run properly. those 2 seconds it is most likely running off a surplus of fuel from priming or something of that sort.
Check fuel lines and fuel filter for obstructions. I reccomend replacing fuel filter also. If this does not help is may be a fuel issue in the carburetor.
Feb 08, 2012 | Garden
This is a lawnboy mower about twenty years old and has run fine intil about a week ago. Now...after starting...It will surge up and down at full speed...then start to bog down unless throttle is placed...
drain all gas out of the tank and carb the new gas with 10% ethenal is ruining old gas engines after everything sits for a day install a plastic shut off valve in gas line. put high test gas with the seafoam then turn gas valve off after every use it will run good. then call your congressman and complain otherwise we will all be replacing any engine older than 4 years old
Sep 15, 2010 | Garden
Rough low throttle on Lawnboy Dura Force Pro 6.5
Sep 28, 2009 | Garden
My LawnBoy mower 195 cc 4 cycle that starts fine. After about 5 minutes of grass cuting the engine starts to cycle until it dies. If I leave the mower sit for about 5 minutes, it again starts fine and runs...
Jul 30, 2009 | Garden
Jim
Jun 04, 2009 | Craftsman Garden
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Garden Logo
Top Garden Experts
roeb
john h
Marvin
Marvin
