SOURCE: Set security code
you have to search the www for software to lock your mobile applications......
SOURCE: Forgotten My Phone Lock Code
Please Goto a Sony-Ericsson Service Centre They will Sove It ...............................
Ok, THIS WILL WORK! It worked on my W580i and it wasn't even supposed to. FIRST! Download (8.8MB) XS++ From HERE:http://forums.se-nse.net/index.php?showtopic=16338
SECOND! No install. It just runs.
Make sure you have ALL drivers for YOUR phone. That should be under the bettery. Under model... or something like that. HERE! http://www.nodevice.com/driver/company/Sony_Ericsson.html
Take your phone, turn it off. Start this program and click on connect. You'll have 30 seconds to plug your phone into your computer and HOLD C The entire time! (the delete button or 2). If connected, then click at the button: GDFS. There will be a phone lock reset to "0000". Click it. It will take no more than 45 seconds. I promise. Unplug your phone, and vuala! If your phone won't turn on, try pulling out the battery, putting it back and trying again. This program is also good for flashing phones, and putting flash menues on your phone. Also unlocking it and debranding it. GOOD LUCK!
SOURCE: forgot my security code
Yup Sony Erricson codes are easy to remove.
Here is the solution, which i'v tested many times.
i used XS++ with DCU60 cable (i.e; USB cable which comes in the box),
Download 3.1 version here
use XS++ 3.1 and Another version
1) Switch off your phone,
2) run XS++.exe
3) In XS++, click Connect.
4) old C on your phone and then insert the USB cable.
5) u can get some information about your phone when it's connected,
6) click or tick GDFS at the bottom.
7) Then click Phone Lock, and reset it to 0000.
8.) click Settings at the bottom, then Disconnect.
9) unplug the USB cable, remove then reinsert the battery
10) switch on your phone
The code will be set to 0000
Enter it, and chage accordingly.
Kinda, You are done.
If i was helpful, kindly do Rate!
SOURCE: how to lock k790i keypad with a password?
ya u can do this with settings menu in security settings where u have option lock phone & need to insert ur lock code
OR
u can get an auto lock software from net & install it
