SOURCE: shallow well pump made by wayne well is 22 feet deep pump runs no
Inspect the jet thru the suction pipe or the removable plug if the pipe isn't inline with the center of the impeller. The jet is very small, and easy to get something stuck in there. Then prime and leave the pressure pipe closest to the outlet slightly loose to let air out. Once you get good pressure you can tighten the pipe. Sometimes you have to prime more than once to get all the air out of the well pipe.
SOURCE: Removal of impeller and screw - is it clockwise or
The attached may be able to assit you.
http://www.goulds.com/pdf/7381.pdf
Tom
SOURCE: i have a wayne fuel dispensing pump model#730 that
Check the suction line for leaks. No leaks-how about the
checkvalve? If it's okey, open and fill the priming port with fuel to full level. and start the pump. What happened? Send us your e-mail comments, and may the Lord Almighty bless you.
SOURCE: I just purchased a house
Maybe... and maybe there is a resisriction somewhere...
But the flotec pumps are ell cheapo and you should 1st find out the depth of the well, then go to a reputable plumbing supply houde and get there charts out to figure out which pump you need to get the water flow you want at the depth of your well....got that?? :-)
heatman101
