Question about Measuring Tools & Sensors
Need sensor for smart gear clock and weather clock
My Smart Gear STG-5939-KB, Weather Station does not indicate the correct day. Instructions say it will adjust to the date. The date is 5/4 but the dat says TUE. Any ideas?
Your Smart Gear Weather Station may be defective. I have an atomic lock that indicate DST all year round but changes time correctly. One other thought: your weather station may be set for the wrong year.
May 04, 2018 | Measuring Tools & Sensors
I have the Atomic Clock model W86111. I had to change the batteries on the outside device. The clock outside temp just flashes 63.5 all the time. How do I make it sync to the device outside?
Remove all batteries from outdoor sensor and weather station.
Press one of the buttons on the weather station at least 20 times to clear all memory.
Verify that the weather station is blank before proceeding (there may be lines painted on
the screen that will show when power is removed).
Leave both units without power for 15 minutes (very important).
Insert fresh batteries into the clock.
Insert fresh batteries into the outdoor sensor.
Press the TX button on the outdoor sensor to transmit RF signal.
Keep the outdoor sensor 5-10 feet from the forecast station.
When RF connection is established, the temperature will appear on the station. Allow the
outdoor sensor and weather station to sit together for 15 minutes to establish a strong
connection.
Oct 14, 2017 | Home
My Smart Gear STG-6007-BB weather station won't pick up the outdoor temperature from the remote sensor. I changed the batteries and reset the unit, but it still doesn't work. Any suggestions?
  • Remove all batteries
  • Install batteries in remote sensor. Allow time for it to begin sending temperature information
  • Install batteries in indoor unit. You should see temperature displayed
Cold weather can cause loss of temperature information
Dec 17, 2016 | Measuring Tools & Sensors
Smart Gear Weather Station. How can I adjust time?
George, RE POST make model # and your complete question, so we at Fixya can answer your question effectively.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Mar 20, 2016 | Measuring Tools & Sensors
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
My remote sensor Tx14TH-LCD-B started flashing several days ago and I have gone thru the factory reset new batteries and decided to buy a new sensor then discovered they have been discontinued along with...
I assume you have tried removing the batteries at both ends, reinstalling batteries at the sensor end then the indoor end, waiting without touching anything until the outdoor temp registers and heaving a sigh of relief as things are back to normal. I also assume since the word atomic is in the header that you have an atomic clock function. If nothing works or doesn't work right you probably need to replace the system.
I have a much simpler LaCrosse system which, at this moment, is showing an outside temp of 56 degrees BUT the clock doesn't work and failed early on. I share your frustration.
Nov 04, 2013 | La Crosse Technology La Crosse S98642...
I need help setting the alarm on my radio controlled digital clock.
1- Turn over your Seth Thomas digital clock. Use your finger to remove the cover to the unit's battery compartment. Insert two AA-size alkaline batteries into the battery compartment and replace the cover. Certain Seth Thomas digital clock units will also have an optional alternate power source in the form of a standard AC power cable that plugs into a wall outlet in your home.
  • 2 Place your Seth Thomas solar-powered digital clock in front of a light source, such as on a window sill or beneath a lamp. The black strip on the top of the unit is the solar sensor, so as long as light is shining down on that strip, your clock will be powered on and ready to use. The sensor stores energy throughout the day so that it can work at night with no direct light contact on the sensor.
  • 3 Press the time zone button that indicates your current time zone. These buttons are located on the back of the unit. For example, if you are in the eastern time zone select the "EST" button. Turn the unit back over. It will now be displaying the correct time on its digital screen.
  • 4 Use the "Alarm" switch (if applicable) to enable and disable the clock's alarm. Press the "Alarm" button, followed by the "Hour" and "Minute" buttons, to set the appropriate alarm time based on your needs. Use the "Alarm HI LO" switch to set the volume for the alarm.
  • 5 Press the "Weather" button to tune your Seth Thomas digital clock to its built-in local weather radio station (if applicable). Certain Seth Thomas clocks have this radio weather functionality built in, while others don't. If yours does, the aforementioned "Weather" button will be located on the front of the unit.
  • May 28, 2011 | Seth Thomas Radio-Controlled Howard Wall...
    Measuring Tools & Sensors Logo
    41 people viewed this question
    Top Measuring Tools & Sensors Experts
    Vuk B
    Tom Chichester
    Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
