Question about Miscellaneous
Want can i do if i'm looking for job at airport
  • Miscellaneous Master
  • 5,040 Answers
Make a resume' and send to all airliner co. there and the air port authority , if in USA are you, even to FAA.gov USA.?
Posted on Jun 18, 2019
SOURCE:
The airport code for hawaii
The common airport codes are:
  • HNL Honolulu International Airport.
  • ITO Hilo International Airport.
  • KOA Kona International Airport at Keahole.
  • LIH Lihue Airport.
  • OGG Kahului Airport.
Or look at this site:
or look at this site:
http://hawaii.gov/ito/airport-information/faq
Feb 06, 2015 | Home
Airport sign in keep saying wrong password
Delete Preferred Network(s)
  • System Preferences > Network > Select AirPort > Advanced > AirPort tab
  • Under Preferred Network, use the minus button to delete the network(s) you regularly use from the list
Delete AirPort Keychain Entries (Note: only applies if you connect to AirPort/Time Capsule routers)
  • Launch the "Keychain Access" application located in /Applications/Utilities
  • Click on the "Kind" filter at the top, and look for any "AirPort network password" entries...and delete them.
  • Restart, or log out then back in.
Add Preferred Network(s)
  • Under Preferred Network, click on the plus button to add any preferred network(s).
  • Restart or log out then back in.
Jul 02, 2014 | Apple iBook G3 Mac Notebook
I broke the wire that connects to the airport card the little pin is still connected to the airport card what can i do about it????
The wire you broke is the Airport antenna cable. It is a replaceable part, but replacement involves disassembling the display assembly, and is not a job for the inexperienced.
Nov 17, 2010 | Apple iBook G3 Mac Notebook
Someone helped me hook up my dell laptop to the airport exteme wireless. The wireless is on the actual new laptop, but it asks for a security key. I have no idea what the security key is any ideas? ...
If your network is being created by an Apple AirPort base station, use AirPort Utility to put the base station into "manual setup" mode, then pull down the "Base Station" menu and select "Equivalent Network Password". Try the value shown there.
Oct 13, 2010 | Apple AirPort Extreme Base Station
Only one computer on my wireless network finds Airport Express. I have Airport utility installed on both of my laptops in my network, but only one of them finds the Airport Express? I can ping the...
Dial 1-800-204-4427 US Toll-free Number & Get the best assistance for Trusted Apple Technical support. We proffer an online Apple Technical Support assistance to the customers and fix their glitches in a professional manner. Read More... Apple Customer Support Number 1 800 204 4427
Jun 19, 2017 | Apple AirPort Express Base Station with...
My imac loses its wireless connection, regains it,
Best place to look is ebay as these cards are nolonger made. First try and plug and unplug your card a few times.
May 13, 2010 | Apple Airport Card - Network adapter -...
My imac loses its wireless connection, regains it, loses it, regains it.... I'm assuming the airport card has begun to malfunction. Looking for a replacement card.
There is a function for the airport called "robustness". you can enable it in the icon in the upper-right of the screen. It looks like a wi-fi signal icon. Click there, then click on "connection robustness" I think it is called. I am pretty sure that will work, unless the signal is just too weak, and that could be the reason it falls off frequently. If that doesn't work for you, I am in Colusa, and have 2 extra airport cards I am selling for $5 each. Good luck.
Bruce
Mar 22, 2010 | Apple Airport Card - Network adapter -...
Imac to finding airport express. other computer
Several steps to try.
1) Make sure your iMac Airport card is powered on. You can do that with the Airport icon in your menu bar (looks like a pie wedge), or go to System Preferences / Networking / Airport and make sure Airport is on (also, enable "Show Airport Status in Menu Bar" to get the handy icon).
2) Temporarily move your iMac as close as possible to the Airport Express. Pull down the Airport icon and see if the name of your network shows up. If it doesn't, you have a bad Airport card in your iMac. Otherwise...
3) Move your iMac back to where it was. See if the Airport icon still shows your network's name. If not, you may have a bad Airport antenna in your iMac, or you may simply have too many intervening walls or be at too far a distance.
Nov 16, 2009 | Apple iMac G5 Desktop
Using to Print Wirelessly
mac or windows? Here's the airport express firmware update which resolves a lot of known issue regarding the express.
windows:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63forwindows.html
mac:
http://www.apple.com/support/downloads/airportexpressfirmwareupdate63formacosx.html
May 29, 2008 | Apple AirPort Express (M9470Z/A) 802.11g/b...
Miscellaneous Logo
13 people viewed this question
Top Miscellaneous Experts
Bill DeLisi
Bill DeLisi
Rachael Newton
Rachael Newton
Level 1 Expert
Roger Goldberger
Roger Goldberger
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
