SOURCE: Steam Wand Broken
I soak the steamer tip in flat cola overnight to clean out milk deposits. Run water, not steam through it after that to rinse.
Sometimes I need to use a toothpick to lift off the softened deposits.
SOURCE: same problem with my classic gaggia.
Hi Marc
Just bought one this week with exactly the same problem. As a last resort I opened it up to find the pump had come off the rubber support kinking the pipes beneath so no water could get in.
Undo the 2 philips screws on the top, take off the lid and water filler spout and take look. Looking down from the front of the machine, the pump is at the back to the left. If it's just floating in space as mine was, simply push it gently back into the rubber support beneath making sure you don't kink the pipes.
Mine came by DHL from Italy with no right side up marked on the box, so no wonder it came loose!
Hope this fixes it.
Matt
SOURCE: gaggia baby espresso machine - water comes out of
Remove shower and screw, then run brew button, if that works clean shower, if not remove allen wrench screws and clean diffuser and valve on spirng.
SOURCE: No water coming through portafilter to make espresso.
You have a stuck check valve. Try running the pump with the steam knob open, then shutting it then, opening it 4 or 5 times and see if it will pop open. Make sure that you don't have the portafilter in at the time you are doing this.
