Question about The Computers & Internet
My left click button is working hit and miss, I put a new battery in and no change. I changed settings to the right button and it works fine then change back to the left and it doesn't work.
  • The Master
  • 5,049 Answers
Posted top computers is it, if yes, what PC, and what OS does it run. we cant guess what you own, must be said or answers tend to lag and be wrong.
Posted on Jun 18, 2019
SOURCE:
yooperbud
  • 8637 Answers
SOURCE: Microsoft Wireless Laser Mouse 6000 (Model 1052):
Normal 0 Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. Put the pointer on the left button and then go to the drop down and make sure the buttoon is set properly.
Hope this helps. Bud
Posted on Jan 16, 2009
wipdhuls
  • 133 Answers
SOURCE: stopped working. battery changed, reset button
Dear Barb400,
You might have tried this already however just wanted to make sure ... Did you try connecting the mouse to receiver .. I mean .. there is a connect button beneath the mouse and there is a connect button on the Receiver that's connected to the USB of your computer .. Did you try pressing connect button on receiver and mouse simultaneously for 2 to 3 seconds and release .. If not then please let me know if this works..
Even if it doesn't work still I would love to hear from you so that I can suggest some other troubleshooting steps.
Hope that works for you :)
Regards,
Srinivas
Posted on Jun 21, 2009
ta_mcguire
  • 125 Answers
SOURCE: acer d150 left trackpad button not clicking/working
go to control panel click on mouse and set for right handed
Posted on Jul 30, 2009
rcalorisian
  • 313 Answers
SOURCE: my eeepc right click pad button isnt working.
I am not sure how old you eeepc is, but the touch pads and it's buttons are a common issue. Try to buy a wireless mouse. it is much faster and easier and cheaper to fix. But if it is under warenty have it fixed. it just depends on your needs. A mouse will run you $20-$40 and the touch pad will cost you more $ or a month or so to have it fixed.
Posted on Sep 08, 2009
  • 19 Answers
SOURCE: My acer extensa 4630z laptop's keyboard is not
try blowing out the dust and particles from under the keys. Are you in NumLock, if so hold the "fn" button down and press your F11or which ever F key says NumLk on it , that should unlock the keyboard. Depending on the age of the unit it is possible that it just may need replacing.
Posted on Dec 22, 2009
How to turn off monitor
1. Go to the desktop
2. Right Click
3. On that list, you should click personalize
4. In the lower right hand corner, click Screen saver (It's in blue letters)
5. In the bottom left hand corner of the window that just popped up, click "Change power settings"
6. In the left side of the new window, (It's in the light gray area) click on "Change when the computer sleeps"
7. Then from here you can set when you want to turn off the display and or put the computer to sleep after how long you have been inactive.
8. Remember to click the "Save changes" button to save what you've done.
May 25, 2014 | Total Gym Cyclo Trainer
Left click will not work
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7 then click on the >> all control panel items scroll to mouse in the buttons tab you will see the defaults left button right button and middle wheel click you might have to set the left click button again in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar . Or disconnect the mouse from your computer restart.
Change mouse settings
http://windows.microsoft.com/en-US/windows7/Change-mouse-settings
Hope this helps.
Jan 23, 2013 | Toshiba Satellite C655-S5123
I can't figure out how to change from right hand click to left hand. Please tell me how to do it. thanks
start run control panel mouse/ buttons/ configuration
press ok............
cheers
Mar 27, 2011 | Computers & Internet
Computer screen too wide
You just need to change your screen resolution to fit the monitor. Right click an empty spot on the desktop and left click on Properties. This will bring up your Display Properties. Click the Settings Tab at the top right and you will see a slider bar on the middle left. Move the slider bar to the right or left one bit at a time and hit the "Apply" button. The screen resolution will change and if it does not look right, then cancel the change and go to the nest resolution setting. Repeat this process till you get a resolution that works well with your monitor. Cheers!
Oct 28, 2010 | Microsoft Windows XP Professional
Clicks of my laptop not working
Start button > settings > control panel > Mouse properties >device settings > click on the device listed and click settings. Click on buttons in the left pane and make sure the buttons are enabled. If they aren't click on the box to enable and hit apply, then ok.
Sep 04, 2009 | Acer Aspire 5610-4648 Notebook
Need to know how to set a new code in a Telko S050A
push any four numbers, then push the bottom left code button one time and that will set up a new code for you. Then enter the new code and hit bottom right button to either arm or disarm the alarm.
Aug 09, 2009 | RCA 25110RE3 Phone
Can't turn off PIP on Sony XBR videoscope TV
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Televison & Video
Wireless Intellimouse Explorer Not Working.
Normal 0 Normal 0 Recheck the magnifier to see if its set right.
Go to Control Panel and click on the Mouse icon. Then the mouse properties will appear showing the mouse buttons. In the Left column is the button settings. The bottom one is the Right Button, which is set for Magnify. Whenever you hit the Right Side button the magnifier will turn on. To turn it off, hit the Right Side Button and off it goes. You can change any of the button settings by clicking on the drop down.
Sep 01, 2008 | Microsoft Wireless IntelliMouse Explorer
THE 4-way scroll button IN MY ASPIRE 5100 DOESNT WORK
Double click the icon in the toolbar. Click the device settings tab and then hit setting. select buttons in the list on the left side. Hit the plus sign(maximize) and select scroll up button action....scroll down button action...Etc. For each action select what you want it to do and just hit apply and move to the next. Once you have selected the action for scroll up, down , left, and right hit apply again just to be sure and try it. It should work. I just did it on my 5630 but Im assuming it works the same.
Aug 14, 2007 | Acer Aspire 5100 Notebook
Open Questions:
Computers & Internet Logo
11 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
