How do i unlock my G600 i really need the sim lock to access my phone, can you help?
BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
so it won't ask for network password and shows "Insert SIM" message.
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#
(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
If you find that SPLock is still on afterwards follow the below
After you do the reset, check and make sure that your network lock is active by
pressing *#7465625#.
If it isn't active you must use this code
to reactivate it, *7465625*638*00000000*00000000#.
Then deactivate the sp lock first. To do that input *7465625*77*00000000*00000000#,
(this will reset the lock)
then enter #7465625*77*00000000# (to disable the sp lock).
Then disable the network lock #7465625*638*00000000# and
the phone is finally unlocked
code seemed to have worked for most of the day, then problem returned. I'll try and get refund on phone. Thanks.
I reset the eeromp using code and it also set the imei to zeros. Cost me £25 to get it restored. Next time I but a phone I'll get one on the network I want to use and avoid all the hassle. Thanks anyway.
