SOURCE: changing panel from fahrenheit to celsius
Dawn, press the refrigerator key and freezer key together for 5 seconds. It should toggle between them. Catriver.
SOURCE: changing the oven from celsius to fahrenheit
You will need to push the broil button down for at least 10 seconds then you will see the c change to a f for farenheit
SOURCE: how to convert celsius temperature into fahrenheit ino c++?
Try using the simple mathematics;
- C: variable for the Celsius Temperature
- F: variable for the Fahrenheit Temperature
F=((9/5)*C)+32
SOURCE: Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
SOURCE: I need to change my Maytag oven from celsius to fahrenheit.
I had the same problem, after multiple calls to maytag I finally rec'd an answer. I feel your frustration, didn't need a service call for this.
On my model hold down the keep warm and cancel button for 3 seconds and it will change it.
Hope this helps!
