Contact the manufacturer's customer support for assistance in obtaining a replacement circuit breaker for your Powerfit Vibrating plate. They should be able to guide you on the next steps or provide information on authorized service centers.
Hook up a 100 to 200W light bulb in series with the power plug, light-bulb will light but the fuse wont burn. now you can better trace the short, finding it will turn off the bulbs or dim them
make sure all the plugs are plugged in snuggly turn off the computer again then turn on the screen. next power on the computer. if that does not solve the problem you may have an issue with the video card.
If there are 4 slots, are the slots equally-spaced, or are they located as two pairs of slots, with a gap between the 3rd and 4th slot?
Some computers _REQUIRE_ RAM only in the 1st and 3rd slots, or only in the 2nd and 4th slots.
Some computers "beep" when 3 out of the 4 RAM slots are populated.
Some computers require the size of the RAM in the 1st slot to match the size of the RAM in the 3rd slot,
and the size of the RAM in the 2nd slot to match the size of the RAM in the 4th slot.
Does your computer "beep" when one stick is in the first slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the second slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the third slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the fourth slot, and the other slots are empty? How much RAM on that stick?
Does your computer "beep" when one stick is in the first slot and a matching stick is in the third slot, and the other slots are empty? How much RAM on those sticks?
Mine did that too, I have sent it to Acer for Warranty Acerization, it came back in a week booting fine. Worked for 3 months and then quit again. These boards are used y other cheapos like Gateway and Packard Bell. Solution - trow away the motherboard, keep the CPU and RAM.
