I have a G-Shock GW 300 and I don't have the instruction manual and I do not know how to set the time and date or how to run any of the other functions on the watch. Please help.
Thank you, Bryon
I don't know how much significance this post would make to any now, but I was playing with the watch trying to figure out how to set the time and I have figured it out...
1. Hold the "Adjust" button until where it displays the day of the week starts blinking (This will display the major airport in your area to determine your time zone, mine is "LAX"...to change this, while it is still blinging press either "Time Memo" or "Recieve" to move up or down)
2. Press "Adjust" again so you see "12H" (I guess meaning 12 hour intervals)
3. Press "Mode" (at this point your seconds will start blinking) to change these, againg press "Time Memo" or "Recieve" to move up or down. (usually I skip past the seconds)
4. Repeat step 3 to do your hours, minutes, year, then the date...(order is as follows)
5. When you are done press "Adjust" then everything will stop blinking, and you are done
This is as much as I figured out and I hope this is helpful to anyone that needs it...
At last someone how actually knows how to set my watch for watch repair shops and still no joy! Thanks your advice has sorted it A1
The backlight comes on with wrist movement because you have it set to do that. hold the back light button until you hear a "beep" and it'll change the setting
I have a Casio G Shock gw300(2608) I have had it for about 3 years and it it wonderful. However, one problem I cannot seem to take care of. With wrist movement the backlite comes on. I put a new battery in for the first time and month later it started doing this again.....HELP!!
Mike Postoian
don't have the instructions and can not set time
same problem as bkoreilly'
i don't know how to set the time and date
how do you set the time and date
well ihave a g-shock wr200 and i dont know how to set the time or date, if you could help me it would be much appreciated.
The time is outta whack, I tried setting the time by using the satelite with lax but i forgot how? The time is wrong in all sections of the world. Is this just a battery problem?
can't set time
i just changed the batterie and im having trouble setting the time
I have a Casio GW-330A wristwatch. Today is daylight savings time in Michigan. How do I reset the time?
can not set my casio g shock
how do i set the time
I lost instruction booklet dont know where tostart
set to 24 hr military time
set day of the week
Cant set the watch 1 hour ahead for day light savings time.
I have a casio g-shock gw-300 (2608) I have lost the instruction manuel. I need the manuel. Thank You, Jeff [email protected]
set
set date and time
had the battery changed now cant' remember how to set correct time.
I also do not have the instruction manual for the gw-300. how do you set an alarm? I need it to go off every 20 mins... is that possible?
how to set dst
