If you put in an osram "neolux" type lamp--these will NOT often work in Mits. tv sets. And MIts often sends out Neolux bulbs now. A phillpis bulb for this works MUCH better.
Like stated before--May be another bad blub, especially if you used a generic or Neolux one. A phillips bulb WILL work right. Mits sets do NOT like generic bulbs !!
I think you have a dlp tv . always first unplug from wall 10 to 20 minutes to reset micro pross. if that don't work mit dlp tvs are known to have bad filtor capacitors. and always make shure you have good lamp. J.D.W.
let it start up you will here things happening, engine will start first then a buzz to start the lamp if you here all of this you have a bad lamp.You should have a error code let the tv try to start leave it alone and see if you have an error. As soon as you reset the tv you loose the error.
is it tha lamp cracked? are you using original lamp from mits? i founded people using aftermarket lamps with other specks this lamp is 150 watts ,this info its going to help.
if components on the Power board K9A20 and/or K9A21 are shorted. Also, R9A02 may be open. Possible side effects are a deformed lamp exhaust duct and damaged lamp. Replace PWB-POWER part # 934C228003 and if necessary, Lamp part # 915P049010, Lamp Exhaust Duct part # 642B155010, and/or Lamp Exhaust Duct Cover part # 642B156010 let me know if you need anything else
