Sharper Image PD210 MP3 Player Logo
Posted on Aug 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
After conveting a video to an AMV, I no longer have sound on the video
Anonymous
Level 2:
Novelist:
  • Expert 117 Answers
  • Posted on Dec 23, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
117
Questions
Helped
156896
Points
186
2helpful
4answers
I dont know how to load videos and watch them on my eclipse mp3. every time i try to watch something...it says format error even though the video on my mp3 is in AVI format!
This is simply because the Eclipse MP3 player does not read .AVI formatted videos. The videos must be in .AMV format. A good way to convert your .AVI videos into .AMV is to use FreeAMVConverter located at the following link. http://www.amvvideoconverter.net/. You can use this to convert your videos to .AMV format and then they should work.
Hope this helped, NathanTaylor
1helpful
I don't know how to convert music video to amv
You need a format converter to convert your music video to AMV. You can download a free AMV format convert at the following website: http://www.brothersoft.com/downloads/amv-convert-tool.html
Good Luck, I hope this has helped you. Please rate me, Thanks
6helpful
2answers
I can't put videos on my mp3/mp4 player
Sir please connect your device to your computer and see if any indication is shown on the display of your mp3 player
if yes then open my computer and a new device will appear under the removable devices...please open it and if there is a folder named mp3 to music then also open it and copy paste all music you want
If not then please make sure in the settings of the device that USB is set to MASS STORAGE MODE
Thanx and i hope this helps
PLease rate this solution
How do You download video into the Innovatek Inno - 89 MP4 Player? Please help
I have the player for my brother for christmas and had to pre-load it for him.
You have to download a program called AMV video converter.
This particular mp4 player only uses .amv movie files.
Some use .amv and .mtv but this one uses .amv and you can convert almost any movie file .mpg, .mpeg, .avi, ect... into .amv
Then just drag and drop it and play!.
Make sure you check all settings and make the video conversion big enough to see on the player.
God Bless and good luck!
Knowledge
AMV movie dowloads - JNC Movie Mojo ( SSFM-220 )
How to convert wmv, asf, avi, mpg to amv files? iOrgsoft AMV Converter is an easy to use video-to-AMV and AMV-to-video converter application that enables you to extend MP4/MP3/MTV capacity by converting various video files into AMV workable format. AMV Converter has powerful editing capacity that you can customize source video files into different resolution, bitrate, frame rate, etc.
If you have lots of video sources but unable to get them onto your player, AMV converter should be your ideal choice. Please follow the guide below on how to convert AMV video file to or from using the iOrgsoft AMV Converter.
spacer.gif icobuy.gif Buy Now spacer.gif icon-downarrow.gif Download RMVB Video Converter free trial spacer.gif How to use video to amv Converter
How do you convert video files into AMV video files that are compatible with your mp3 mp4 player?
Step 1. Download and install iOrgsoft AMV Converter
iOrgsoft AMV converter is a simple-to-use program with intuitive way of operation. You are supposed to download a trial version to evaluate the program by converting video into AMV, we welcome you contact our customer service with your problem.
Step 2. Load video info
Click ADD Files to load video info. You can load as many video files in different formats as you like, the batch mode and powerful code pack within the program can easily take care of every thing.
Step 3 Change defaults setting
After load video files, you can now tweak various values that directly impact on the output result. Hit Option will open a window where you can trim, crop and add effect to the source video. Finally, check the box before Merge Files into One on the bottom of the panel, all the files can be merged into one then.
Step 4 Convert video
Hit Start, the entire list of source video will turn to your delivery format as you preset The time takes vary file and setting you have made..
2answers
I cant get my video in my Mp3
in mp3 player u cant play the video
u must get a mp4 player only then u can watch videos in that
2helpful
2answers
How can i download movies/videos on my gpx ML638b?
all you need to do is go to google and download a AMV video converter tool. once you do that put the video on the converter and start it. then click on My Computer, then click on GPX MTP Device> Removable Storage>. and then copy the video wherever the conveter saved it and then copy it. then paste it in the Music Folder on your mp3.
Ps. i am haveing a problem with charging it. i got videos on it but i cant charge it here is my problem...
http://www.fixya.com/support/t1568066-get_charge
3answers
Video files
Try put in it in manually Go to the following folders Record > AMV > and put the video in there....remember the video must be converted into a AMV file
Top Sharper Image Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
SmartAviator
SmartAviator
Are you a Sharper Image Audio Player and Recorder Expert? Answer questions, earn points and help others
