Hi Steven, I understand your frustration.You may have to reset the GPS,attached is an owner's manual link to download.
I am glad to assist you. good luck!
JP
https://www.manualslib.com/manual/256133/Garmin-200.html
SOURCE: my garmin nuvii 200 is stuck on a foreign language
Ah ha, someone decided to play a little joke with your Garmin. (I've done the same with someone else's cell phone; set it to Portugese and they'll search for days to correct it!) Fortunately, all of the Garmins I've played with are typically icon driven menus. I'll assume you touched the wrench icon in the lower right corner to get into the setup display. From there, you should see icons for 'Map', 'System', 'Time', etc. If you don't see the 'Language' icon, use the down arrow to go to the next screen. If that doesn't help, I would do a factory reset and that should take you back to the factory settings.
SOURCE: HP Laserjet 3030 printer/scanner/fax Language has
How can i change HP laser jet 3030 printer's language?
SOURCE: Changing Language on Tomtom one 130
Hi rharris9,
After starting your TomTom , tap the screen . Scroll left or right if needed to find "preferences" . Once in Preferences , look for a 'lips' icon and it should also say underneath " Change Voice". Select that and you should be presented with a selection of voices and languages to choose from.
Good Luck
SOURCE: A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the
network while others are locally connected to a computer. I have worked
with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold
down the button to turn off then turn back on. You can also unplug it
from its power source then plug back in.
Power cycling this printer should reset the language to default
(English) or it will let you select the language when it comes back
on. If that doesn't work then you can try to change it using the
installed software.
Considering the fact that someone accidentally changed the language, I
am assuming this printer is connected directly to a computer that you
all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB
or parrallel port) then you should have an HP Toolbox app or some other
program that allows you to configure software related settings for the
device. Open this tool and you should find an option for the language.
This may not be available, depending on how the installation was
handled (if it was installed using the CD provided by the manufacturer
or installed using downloaded drivers).
Try this out and let me know if it helps.
SOURCE: how do I change the
select the wrech icon on main menu, then select the wrench icon again if given the option. Then select the lips icon, and you'll have 2 options - voice and text - and they won't be spelled in english, but go into both separately and scroll until you find the english choices. I had this problem and couldn't find the correct solution online. I fiddled for over an hour and finally figured it out.
