SOURCE: Kenmore ultra elite microwave hood combination
F9 code can mean something different depending upon the particular model.....
1.) IF your Microwave uses "UltraWave technology"/"SmartWave technology"...Then either the Magnetron has failed or the Inverter board has failed OR maybe the control board has failed (HUH?).
2.) IF your Microwave does NOT use "UltraWave technology"/"SmartWave technology" then one or more of the door switches has failed.
** "UltraWave technology"/"SmartWave technology" **
I'll explain a few things about this wonderful technology...
The control board (accepts the pushbutton commands) has to talk to the inverter board to tell it how much power should be applied to the magnetron. The inverter board will then power the magnetron and inform the control board if the magnetron is working OK.
If there is something wrong with the magnetron or inverter board or a there is a communication breakdown between the control board and the inverter board...WA-LA-----F9----
A pretty reliable test for the Magnetron is to operate the oven and listen for a ticking sound 5-6 times about a second apart. If you can hear the ticking....The magnetron has failed..if no ticking, the control or inverter board failed.
Note: This 'technology' may come in other flavors as well
SOURCE: kenmore microwave 721.80412500
The owner's manual should spell that all out.
But if you don't still have yours, you can download one via Sears' "Manage My Home" site here. While it's free, you will have to register.
(You *may* be able to download it here without logging in. If not, go ahead and register. It's free.)
SOURCE: F7 Error code on Kenmore
On the tech insert found in a cavity under the cover of my Kenmore MHC, the F7 code means the inverter board ($90 - $130 street price Fall 2008) is bad and needs replacement. I am having this problem, and verified that the magnetron was not shorted to ground with an ohm meter. I verified with a volt meter that the magnetron was not getting any voltage applied across the cathode from the inverter board when the microwave is running ("WARNING"- don't do this test with the magnetron connected.) I have an inverter board on order.
SOURCE: I have an error code
Quoting another board:
Sears Kenmore Whirlpool LG 721.63683300. F-9
on this microwave IS inverter related.
There is a service tech
troubleshooting document stuffed in behind the control board cover
which has some testing procedures. My problem was the magnatron and
checked out bad with the help of this document. It would run for a few
seconds making clicks and then say F-9. It has been working great since
I replaced the magnatron PN 6324w1a002c.
f9 model 721.63764300
Kenmore
Elite 36 " over tne counter microwave is supplied by LG made by Gold
Star, made in China. It's main problem is the high voltage inverter
board supplyed by Sears Parts. If you get a F-9 code on your microwave
display screen and the micro quits it's probably this board. Reset the
machine by pulling the power plug and waiting an hour. If it is the
high voltage board is at fault it will probably fail after 45 seconds
of start up. This part is really hard to get at but is less than $100.
A qualified technician should be able to remove and repair this item in
less than hour. Some techs will quote you $300 labor, don't buy it, it
should cost a $100 or less. No need to buy another microwave.
