Hi Cameron, I would definitely NOT bypass the locking mechanism for safety reasons.Here is a link to where you can buy one at reasonable price.
\Good Luck!
JP
https://express.google.com/u/0/product/4585249144643607774_11490809760759412246_110287632?utm_source=google_shopping&utm_medium=tu_cu&utm_content=eid-lsjeuxoeqt>im=CL6tgurstNTl_gEQp92Gxa2EgeLrARjgl6YJIgNVU0Qo4LLK6AUwkLbLNA&utm_campaign=110287632&gclid=Cj0KCQjwl6LoBRDqARIsABllMSYKcT7fAyBzjuZv2aPhoFVyT2MyVvIb12QjCTxZL60ch9F83uernrAaAsKlEALw_wcB
SOURCE: washer control is locked
The following link explains how to correct a Control Lock problem for your washer:
http://www.fixya.com/support/r2469429-kenmore_elite_amp_whirlpool_duet
I know this link is for Kenmore Elite and Whirlpool Duet. The newer model Maytags are manufactured by Whirlpool (which also makes the Kenmore Elite) so these instructions should apply. Keep in mind control panel options between models may differ slightly, but the locking feature instructions should be printed on the front panel. If you are not sure, there should be a tech sheet inside the washer behind the lower kick panel under the door. If not directly behind the panel, the sheet should be affixed to one of the interior cabinet walls.
If these preliminary measures do not correct the problem, you may have a more serious problem. If you have questions, or require additional assistance, please let me know. I hope this helps you.
NOTE: The Control Lock feature is a built in safety feature that allows you to lock the front panel to keep small children from manipulating the controls.
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side
of panel. This is the child lock feature, do it again & it locks.
If
helped, pl rate me good!!
SOURCE: kenmore top loading washer locking lid switch bypass
Yes. Snip the wires at both sides of the switch. Then fuse the wires together with electrical tape. But before you do that...you state it's a 2011 model? It should still be under warranty.
