TRIMMER RUNS SHORT TIME THEN STOPS WAIT 30 SECOUNDS RUNS 15 SECONDS AND STOPS
SOURCE: CST1000 Black & Decker Cordless Trimmer/Edge won't start
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/CST2000_TYPE_1
Part number #243614-00.
It's a microswitch made by Honeywell that costs about 5 bucks plus shipping.
The attached file has the schematic and parts list.
The CST2000 is well worth spending a few bucks to keep it going. Finding a local B&D authorized service center near you will even save you the shipping as they can order it for you.
Every other component is pretty dependable- the motor, battery, wiring, charging system, spool system- all built to last.
Only down side is you really only get 20 to 25 minutes of hard weedwhacking before you need to recharge. Of course, it's time for a cold beer in the pool by then.
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
SOURCE: does not automatically feed out line
I am a bit upset. I purchase a Black and Decker Trimmer and you guys want to charge me almost 10$ to give me a little bit of advise on a problem. Than I find in that email that if I have fixed the problem you want me to email you and tell you how I did it. FOR FREE. Well I did fix it. If you would like to know how mail me 10$. Only fair. [email protected]
