Hissing and popping is normal, it is the defrost heater.
Check that the freezer is level
Check the drain pan
Check the condenser fan
Check the evaporator fan
Inspect the compressor mounts
Water on floor outside of freezer?
* Check the drain pan
* If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve
Water inside the freezer?
* Check for a clogged drain tube
* If you have an ice-maker, check freezer and ice-maker for level
