SOURCE: onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
SOURCE: bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
SOURCE: 6 disc CD changer is stuck
This happened to me a few years ago. It wouldn't eject the CD for a year. I literally smacked the side of the dash where the cd player is located and it came out the next time I pressed eject. I found that same solution in a couple of forums. I had to do it a few times. I think the CD just has to allign with something to eject properly.
SOURCE: 6 disc changer will not eject cds==
One common solution is to disconnect the negative battery cable for 10minutes. When you reconnect, the stereo should reset itself and allow you to eject your CD's . Best of luck!
Greg
SOURCE: 6 CD Changer Stuck (Lexus LX 470)
Open the eject door and at the lower right side of the cartridge their should be a small indent that looks like you could poke it with a medium point pen. That's a reset for the changer. If that does not work, you will need to remove the changer from the car, pull off the top, plug the cable back in and hit eject. look for the arm on the backside of the cartridge and give it a nudge. It may just be stuck. Loading mechanisms usually do not fail before the optics or other!. If you need further help, post a comment with any model #'s on the changer and I'll look for info and help some more. Hope this helps.
