Heating & Cooling Logo
Sambhu Posted on Jun 17, 2019
My Carrier inverter ac error EC after every 20-30 minutes run, what's the problem
2 Related Answers
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Jul 13, 2018
SOURCE: How do we fix error code EC for Kolin inverter aircon?
Model number is needed.
Lovely
  • Posted on Apr 09, 2019
SOURCE: My carrier breezo inverter ac is showing bl on led, although its filters have been cleaned 5 days ago by carrier technicians.
Was the problem solved..
I am facing the same problem for last 8 months
But the technician is not able to solve it..
They don't even know what bL code is for
Please let me know if u were able to solve this problem.
What is the meaning of error p9 in carrier window type inverter?
Error Code Definition: (Unit Size 36K - 42K) = IPM over temperature protection. Carrier AC Indoor Unit Displays Error Code: P9. Error Code Definition: (Unit Size 18K - 24K - 30K) = NA. Error Code Definition: (Unit Size 36K - 42K) = Open Contactor.
https://removeandreplace.com/2017/08/11/carrier-split-system-air-conditioner-error-codes-and-troubleshooting/
https://www.youtube.com/watch?v=M-fLGOYL84Y
My 1.0hp carrier window ac remote stop indicating ec on display,what is the problem?
EC means there is a freon leakage detected. Get it serviced by an AC service person.
I have a p6 error displayed on my carrier ac after it runs for some time
A P6 on a Carrier air con means a communication error between the inverter and power supply PCB on the outdoor unit. In most cases, both boards will require changing. Check with a Carrier Agent first. I can imagine that replacement of both will be a costly exercise.
2answers
E1 Error code on Carrier AC model 42LUV080H.
codes should be listed on inside door panel of unit
Voltas inverter split ac showing e4 error code and got shut down after 5 minutes what is the solutions
My voltas inverter ac e4 error which is communication error.It works fine in sunny day but stops in night or rainy day and shows e4 error.
What is wrong when the display shows EC and the run light flashes 7 times , then stops flashing for 4 seconds , then starts flashing 7 times over and over ?
THE "EC" CODE IS A LEAK DETECTION CODE,, SHOWING THAT THE FREON LEVEL IS LOW, AND YOU COULD HAVE A LEAK,,
? 7 times X EC Refrigerant leakage detection It is time for a service tech
3helpful
5answers
EC error code meaning
Hello friend, thank you for your inquiry!
I understand that you are getting an "EC" error code on your Frigidaire air conditioner. However, it appears "EC" is an invalid error code. It is possible that the error code is missing characters? I show that the error code "ES" or "CS" is valid. In the meantime, I suggest resetting your air conditioner. You can do this by flipping the household circuit breaker for roughly ten minutes. If resetting the power does not correct the issue, could you please inform me of the new error code or if your air conditioner continues to display "EC". I look forward to assisting you. -Matt
Ow do i fix error 59
If you are talking about error code 59 then the error is E.HybC.
E.HybC means that the feedback card on the inverter has been changed.
You must confirm the change at parameter ec.0 or ec.10. The inverter reads the value from the feedback card so all you have to do it hit enter to confirm the value.
If you have not changed the feedback card but the error continues to come back then there is a problem with the feedback card or the control card.
2answers
My orient split a.c shows Ec error in digital display
sir plz answer me my ac orien 1 ton showing EC error on display what is this i can't understand what is this plz reply
Top Carrier Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
