Kenmore 12.8 cu. ft. / 362 liter Chest Freezer 13312 Logo
Posted on Nov 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can my kenmore chest freezer be in the garage during hot summers and cold winters in Minnesota?
Kenmore heavy duty commercial (I think it is 9 cu. ft.)
Anonymous
Level 3:
  • Master 833 Answers
  • Posted on Dec 04, 2007
Anonymous
Master
Level 3:
Answers
833
Questions
0
Helped
518955
Points
1606
Jeremy,
You can put a fridge/freezer in the garage. Be sure that the area is level so you don't warp the case which will cause sealing problems with the gasket. Also, clean the condenser frequently as dust and dirt will reduce efficiency.
Is the freezer being outside causing motor problems
Hello Donna F - Typically freezers are not recommended to be located outside because if the garage temperature is above 100 degrees, it will have difficulties performing optimally due to un-circulating air. Some manufacturers have garage kit design to help with this issue. It is design to solely be used during the winter to provide heat to the coils which trigger the compressor to come on. During the summer months, generally it is not needed.
My kenmore chest freezer is the garage, the temperature outside is over 30 celsius, the side of the freezer where the motor is is very hot, and some other places on the front and other side is warm to the...
The hot sides is normal, this is how they expel the heat from inside the freezer, sometimes it may help to use a fan to help cool. Also make sure there is about 12" of room around all sides of the freezer .
Freezer in unheated/unairconditioned garage it stays cold in winter time but it is not freezing when the temperature is hot in the garage
The first thing is to find out if there is a fan that runs next to the compressor. If not then in the summer the machine is overheating and passing the heat up to the machine itself thawing or preventing the freezer from operation properly
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
3helpful
The front surface of the chest freezer is
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
1helpful
Will it harm an upright freezer if you leave it unplugged during the summer when not in use. It is sitting in a mobile home that gets very hot
Sometimes it does hurt it and sometimes it doesnt. When a freezer sits for any length of time sometimes the freon will leak out. It would be best to leave the freezer plugged in.
3helpful
1991 Kenmore 16 model 253 in storage for 7 years. Plugged it in and turned it nn last night and seemd to run fine, nice and quiet just like before. Today it is not cold and the comressor seems to be r
If the freezer was stored and not running for 7 years it may have lost coolant.  Since the compressor is running recharging the coolant may fix the problem.  Hot compressor might indicate low coolant since its motor is immersed in it.
1helpful
How do I change 9volt battery?
The battery compartment is on the left hand side of the freezer. You can open the battery door with a flat head screw driver. It take a 9v battery.
1helpful
2answers
Outside freezer storage
as long as it is just a freezer, not a fridge-freezer, should be no problem
Top Kenmore Freezers Experts
Jay Finke
Jay Finke
ZJ Limited
ZJ Limited
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
