Question about Garden
My black flag fogger will not produce any fog. I have pesticide in the tank, the nipple is free of debris, the tank has been cleaned as well as the spring for the pump. I'm clueless is what I need to do next
    Top Expert:
  • Garden Master
  • 21,795 Answers
What model -- manual spray fogger or propane fired --
Posted on Jun 18, 2019
2 Suggested Answers
SOURCE:
SOURCE: Fogger does not produce fog
It is common for the nozzle to plug up. If it is brass, it will unscrew and can be cleaned with a very small drill bit.
Posted on Jul 19, 2009
Burgess fogger parts
Need a new piston or plunger, that pumps fogger oil into my Burgess 1443 fogger. Not having much luck, can you help!
Jul 19, 2013 | Fountainhead/Burgess Prod Black Flag...
Parts list for black flag fogger
Where do I buy a replacement front mesh cover??
May 22, 2013 | Fountainhead/Burgess Prod Black Flag...
Trigger is not pumping properly
The plunger needs a new leather, but question is where can you buy it. The problem is caused by the side pull on the plunger causing it to wear unevenly to one side. Could be solved in the manufacture if they would build the trigger to pull it up evenly.
Jul 10, 2011 | Fountainhead/Burgess Prod Black Flag...
Even with the output turned to maximum the fog is thin and dissipates quickly. I have followed the cleaning instructions within the manual and I am still having this problem. What else could cause this?
A common problem is the use of the WRONG fog juice. Make sure you use the manufacturer's suggested product. Make sure you have the correct voltage. Use of a very long extension or attempting to run on a dimmer box also would cause the problem.
Jun 16, 2011 | Elation New Elation Ice 101 Low Fog...
American dj mini fog, I conected to wall, but the machine doesn't gets hot, and not make smoke, why?
There are two switches/buttons on top... You have to both turn on the unit and also activate it with the second button OR using a remote plugin box. The heater takes a bit of time to warm up internally. You will not sense much if any heat outside the unit... They take a few minutes to come on. Make sure you use approved "fog juice" in the unit.
Dec 18, 2010 | American DJ Mini-fog - 450 Watt Fogger Dj...
Shoots liquid not fog
you need to let it fully heat up first!
Nov 15, 2009 | Fountainhead/Burgess Prod Black Flag...
Machine seems clogged
Hello, i just finished a successful repair. i did have to take it apart, and there were springs and ss balls(at fog liquid pickup end that i unscrewed to give easy access to blocked pipe) and such so work where parts won't be easily lost and pay attention during disassembly. The problem with mine(several years old) was blockage in the metal line(pipe) that carries the fogger liquid. i used carborator cleaner and a compressor hose with low pressure. i sprayed in the cleaner and then put air pressure each way back and forth till it eventually yet suddenly cleared out then allowed unobstructed passage. then flushed it to clean it well. BE CAREFUL, it can suddenly spray the cleaner out, safety glasses saved me from a bad accident but my face and lips were stinging from the cleaner, and that was with the end facing away from me(but into a bucket and it bounced back at me). Anyway, reassembly took a bit but now it fogs great again. Mine might be a different manufacturer(burgess) but most likely the same basic scenario. Best wishes
Jun 27, 2009 | Fountainhead/Burgess Prod Black Flag...
May 31, 2009 | Fountainhead/Burgess Prod Black Flag...
Garden Logo
21 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
