SOURCE: retrieve messages away from home on a Panasonic KX-FPG381
You have to set a polling number, you WILL need a manual. Use your keypad just enter this number when you phone home
SOURCE: Voicemail
The answer for both of you is the System Administrator's mailbox. It lets you addl, delete and edit mailboxes and reset passwords.
When your system was installed, you should have been given instructions and passwords for both the Message Manager and System Manager's mailboxes. The access to those boxes is similar and I will not give out that sequence in a public forum, but you should be able to find it in the manual or via email to me...I'll show up on the web somewhere.
Carl
SOURCE: panasonic KX - T7436
Someone has to answer the Message Waiting call to cancel...or, try dialing 700 plus your extension to cancel ALL MW lights.
Carl
SOURCE: How to retrieve all deleted answering machine messages.
'deleted' means just that...can't be done
SOURCE: KX-T7433 - message light does not work
Assuming that the 74xx phone is connected to a Panasonic TD system, the only code is dialing 701 on the intercom, or pressing the MESSAGE button and dialing the 3 digit extension. You can't set your own MW, so you need to do it from another phone to your extension to test it. It also has to be the hardware number ie 101-116 or 132 and not Phantom numbers.
Your 74xx phone could be connected to a TDA or the numbering plan may have been changed, but those are obscure situations.
Carl
