L
Linda Danhausen Posted on Jun 17, 2019
I do not see a clear button under display screen
1helpful
Reset nvram
http://www.support.xerox.com/support/phaser-3300mfp/support/enus.html
Solution : Clear Memory and Restore Default Settings on the Machine NOTE:Clearing memory on the machine will remove information from the machine and restore factory default settings. Make sure that all fax jobs have been completed before clearing the memory, or jobs will be lost.
To clear the machine memory and restore factory default settings:
  1. Press the [Menu] button (located below the Display Screen on the Control Panel) until "System Setup" is displayed on the bottom line of the Display Screen.
  2. Press the [Enter] button.
  3. Press the left or right [Scroll] (arrow) button until "Clear Setting" is displayed.
  4. Press the [Enter] button.
  5. Press the left or right [Scroll] button until the option to be cleared is displayed. (Refer to the table below for additional information.)
  6. Press the [Enter] button. "Yes" will be displayed.
  7. Press the [Enter] button again to confirm.
  8. Repeat steps 3 through 7 to clear additional items.
  9. Press the [Stop / Clear] button to return to Standby mode.
Clear Memory Descriptions Options Description All Settings Clears all of the data stored in memory and resets all of the machine settings to the factory default settings. Fax Setup Restores all of the Fax options to the factory default settings. Copy Setup Restores all of the Copy options to the factory default settings. Scan Setup Restores all of the Scan options to the factory default settings. System Setup Restores all of the System options to the factory default settings. Network Restores all of the Network options to the factory default settings. Address Book Clears all of the fax number and e-mail address entries stored in memory. Sent Report Clears all records of sent faxes and e-mails. Fax Rcv Report Clears all records of received faxes. New Scan Report Clears the information about network scan sessions in memory.
Mem cleared Changed out the batteries and received a messege mem cleared and nothing will work.
Follow this steps to resolve this problem:
1. Press ON to turn calcilator on
2. Press 2nd and then press + key button. TI- 81 displays RESET menu
3. Press 2 to select the RESET, the second item in the RESET menu. The display shows the message Mem cleared. Press CLEAR to clear the screen
If you cannot see anything on the screen, you may need to adjust the graphing TI- 81 calculator contrast:
-To darken the screen, press and release 2nd key, and then press and hold up-arrow key until the display is sufficiently dark
- To lighten the screen, press and release 2nd key, and then press and hold down-arrow key until the display is sufficiently light
7helpful
Hi, the incoming message red light is staying on. However all new incoming messages have been cleared. How do I fix this ?? Thank you DOnna
2 ways to clear this (most likely someone tried to intercom you and pressed the message button on accident instead of hanging up):
way #1:
1) press the "MESSAGE" button
2) on the screen it will display who turned on your message light
3) press the "CLEAR" button (third button from the left directly under the screen)
way #2:
1) press "INTERCOM"
2) dial " *700 " then your extension number (you will hear a confirmation tone)
3) hang up
1helpful
Ink system
The ink system failure message has a chance to be fixed or it may be a permanent issue. It
can be pointing toward a firmware failure in the printer and if that is the case the
following steps should fix it.
Press and hold the “*” key. Press the “#” key and release both keys.
Display should say “Enter Special Key Combo”
Press and release in sequence the "1”, “2” and “3” buttons.
Display should say “Support” and display the FW rev (something like R0631R)
Mine reads R0631M
. Press and release the right arrow button until the display says “System Configuration
Menu”.
Press and release the “OK” button.
Display should say “Hardware failure status”. If not there already, Arrow Key over to
“Hardware failure status”,
Display should say “Hardware failure status: Clear. Press OK to clear”.
Press and release the “OK” Button. Message changes to “Hardware failure status Cleared.
Press Cancel to continue”.
Press and release the “CANCEL” button as many times as necessary, so that, either the
“Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
Wait 30 seconds for the power to get discharged and then plug the power cable into the wall
outlet first and then into the back of the printer.
Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER”
followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK
INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the
initialization process is complete, the printer will print out a Diagnostic Page.
Good Luck!
3helpful
2answers
Panasonic KX-T7433 Message Light
If there is no message and you just want to clear the light, press the message button on the bottom panel of the phone and then the button at the top under the display screen that lines up with "clear". That will turn off the message light.
5helpful
Pf??
PF means power failure.
For short outages the clock may still have correct time
(there is a battery backup for that), but the PF will
be displayed. Setting the clock will clear the PF
indication.
Press 'clock set-start' button, (under clock display)
enter time with numeric keypad,
press 'start' button. (to right of clock)
How do I delete all old messages?
Use the left arrow on the direction circle then when the display shows incoming call log press the enter key. If you want to remove all entries just keep pressing the CLEAR button just below the display screen untill it goes back and show RING inplace of CLEAR.
This if you do not have the buttons below the display screen you need to get a 24 button Panasonic KX-T7630AL Corded Phone and you will have the functionality to do it, the 12 button version can not delete the logs.
On the face of the microwave that displays the time, we just noticed ////////////along the bottom of the display under the time, we unplugged the microwave and tried to reset it, but no change
ok if memmory serves me correct
press the pause clear button with start button at same time
holding them for 5 seconds the micro should beep then press1 3 5 7 for the reset micro screen its been a while since i serviced a micro but i believe this is correct display reset config for micro
2answers
Packard bell easynote l4014 display
Right-click an empty area of the Windows Desktop (your main screen). Click Properties, then the Settings tab. Under the slider labeled Screen area or Desktop size, slide the slider and click apply until you find the size that takes the fuzziness out of your laptop display.
Hope This helps!
2answers
k24674
ADMIN Andrew
ADMIN Andrew
