I have an indesit rg2251 refridgerator and the compressor motor only runs for a few seconds. It starts up about every 2mins but then turns off so the fridge is no longer getting cold. Thermostat is fine. Any suggestions welcome.
A new compressor would be more than the second hand value of the fridge so that's not an option. I've looked at the compressor in more detail and there is a small module on the side which the neutral wire feeds into which then has two m
pins leading into the compressor. There is a ceramic? plate between these two contacts which has broken - what is this? Why would it have broken (fuse?) and would replacing it fix the job or is a compressor fault causing it to break and so would still need a new compressor?
Thanks!
