Hitachi CMP420V2 42 in. HDTV-Ready Plasma Television Logo
Posted on Nov 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hitachi 53sbx59b no picture just a series of red verticle lines. sound is fine
The TV was fine till yesterday. its 7 years old and the picture has gone to just red verticle lines. sound is ok. what is wrong and can it be fixed?
Vista Electronics
Level 3:
Genius:
  • Master 1,694 Answers
  • Posted on Dec 01, 2007
Vista Electronics
Master
Level 3:
Genius:
Answers
1694
Questions
Helped
585277
Points
2786
Possible shorted red CRT = have a qualified Tech take a look...
Anonymous
Level 3:
Genius:
  • Master 1,153 Answers
  • Posted on Nov 27, 2007
Anonymous
Master
Level 3:
Genius:
Answers
1153
Questions
0
Helped
324834
Points
2386
  1. Check D725
  2. D707
  3. CK03
Hitachi 53sbx59b got red power light no picture no sound
Just need to know if you have tried this or cab you try control switch on the TV, Changed batteries, remote camera test and another socket?
I have a hitachi 53sbx59b 53in tv
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
HITACHI 53SBX59B, projection lights don't line up.
You need to have the covergence adjusted.  Consult user manual for instructions on how or have a professional do it for you.
It sounds like bad solder connections in the convergence output circuit. It may also be an intermittant convergence output ic which will need to be replaced.
Hitachi 53SBX59B model and the pow def board is an AP93/23?
Hey there, are you the one that called the company today? If not i will look up our original conversation and post back here soon.
Thank
Tim
Digital Compatibility
TVs, VCRs, DVD players, camcorders and video games will continue to work, even if they are only analog-capable. Such equipment, however, may not provide digital-quality picture and sound.
Hope this helps.
2answers
No Picture
Did you have color problems in past? Most of these sets have convergence problems. Amps goes out. But you should have seen some type of distortion from color, red,blue, green. If no color problems then maybe vertical ouput out or horizontal output bad.
Hitachi 53SBX59b Rear projection TV out of convergence
from you bought the tv and notice that it has that stain on the edge you should have taken it back as it was covered under warranty.now it is getting worse it will cost you to get it fix your tv has a factory defect.you will have to call the repair man to fix your tv.good luck.
No Vertical Sweep
The verticle output iC or the b+ feed is going bad. To fix it your gonna need a multimeter and experience working with tv. Now to its worth??? do you like the set? Does it have all the fetures and fuctions that you liokeand how good is the picture? It shount cost ya more the 125 to 150 for this repair. Good Luck
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
