How to configure dmz on linksys wireless-n broadband router?
Some notes:
If you don't know how to assign a static IP address, let me know and I walk you through the steps.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
i need help with step one!
Look at koyut's solution:
Step 1 Open your web browser, type "http://192.168.1.1 " into the address bar and hit "Enter."
Step 2 If you have not changed the default values, then try (depending on your exact model) the following variations:
Username / Password: admin / [empty]
Username / Password: admin / admin
Username / Password: [empty] / admin
Username / Password: [empty] / [empty]
If this does not help, seehttp://www.routerpasswords.com/index.asp - this might help if you have a special version.
If you still can't get into your router, you have to reset it to factory defaults. This will erase all you individual settings though!
The reset button will clear the stored login information and reset your router to factory default.
Make sure you hold that button for about 15-20 seconds before you release it. After you did this, you can access your router again via the default IP address of 192.168.1.1
One tip - this is what I did after entering all that information (wireless security, port forwarding etc.) again:
I went to each screen and took a snapshot of that window (Press ALT PrintScreen). This screenshot I copied into a Word document and repeated these steps with all important windows. Now I have a little "manual" in case I have to reset my router again and can't remember my "fancy" settings.
Sorry for the horrible layout of my answer...don't know how fixya erased all my paragraphs. Information is there - it's just hard to read.
You can enable enable DMZ in Linksys wifi router by following steps:
You'll need to log in to your router to configure a Linksys router DMZ. To do so, open your web browser and type in http://192.168.1.1 and hit enter. You should see the router login screen. Put in your admin username and password, then hit enter. You will need to go to the Applications and Gaming tab to find the DMZ option.
bessis the post is over a decade old
can you read a Calendar?
try to post to current problems
not ghosts?
and the answer is RTM read the manual at linksys.com.
RTM works do it.
but does not work with MS EDGE. NOW.
nor is walking across the turnpike blind folded.
why not help the living. and not necro post., if I had the power all posts
would end in 3 months or solved is stated.
this is why Fixya is spam pit.
the correct answer is and was for 12 years
is RTM WRT54G2
RTM
https://www.linksys.com/us/support-artic...
RTM . versions. DMZ pages clear as day.
