SOURCE: CUB CADET
Look under the battery holder. There is alot of wires that come down from the ingition and the fuse should be mounted or fastened right under the battery holder.
SOURCE: I need to replace the
Here's a good visual diagram but looks like there is part number variations according to the serial number on your spindle assembly. Hope this helps.
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1050+Tractor+%282007+%26+before%29&dn=0125700050
SOURCE: is there an ignition fuse for the cub cadet ltx 1050
There normally only one fuse is 12 or 20 amp for all power. The only exception is the main power for the starter which is un fused.
If you getting anything worjing when the ignition is turn to the on position then fuse is okay.
SOURCE: Cub Cadet LTX 1050 50 inch. How do I get the deck belt over the PTO?
A common problem:
Make sure that:
1) You have the right belt if it's a replacement.
2) The mower control is in the "DO NOT CUT" or "NOT ENGAGED" position.
3) The tension idler has fully retracted.
