The up and down switch still works, but i cant buy the 4 speed switch separately can't find one anywhere. i even sent the whole unit to a board repair shop, but they were unable to repair. any ideas on what to do now other than throw in towel, given that the rest of it works fine?
SOURCE: Broan Allure QS3
The Problem is the wiring. Take the 2 screws retaining the metal plaque off underneath the filters. You will see the wires leaving the motor going into a "molex" plastic connector which connects two another set of wires going to the control board. Check to see if the wiring colors match from side to side of plastic connector. Ive only seen it happen once but it was exactly that. I do service calls for broan & Nutone
Jean-Marc
SOURCE: Fan speed switch only works on #5
Call your local GMC Dealer and see if they have the climate control panel in stock. What happens is the circuit board on the back of the panel shorts out. The panel comes as an assembly and is very easy to replace. Don't go with a wrecking yard piece. I made that mistake once and it didn't work either. I got one from the Chevy dealer and it worked perfectly.
SOURCE: Heater/ac switch speeds 1 and 2 don not work in 99 Silverado
you need a resister found under your air duct by the passenger floor under dash board auto zone sells these for about 25.00 you may as well buy cabin air filters while your at it . 1 of the screws will be a pain to install back into the duct work I left mine out didn,t make a difference . you might have to order it as they are a comman item oh you will need a vacuum to clean up mess from cabin air filters .this is not a hard job .
SOURCE: Kenmore Elite Dishwasher- The touchpad
jodahabo,
can you post the rest sequence? i would love to try this!
thanks,
the_strum_one
