SOURCE: Battery door broken
Yes i have fixed it. Sorry for my spell, but i try. First i kutt off the little broken plastic-bits with a knife. Demontage the four skrews in the battery flip. I take a little bit stainless string ca 0,5 mm dia and ca 20mm long. I hold this string with a handtool (tong)and put a soldering-heater on the end off the string and pusch the string troth down two times and get two holes there the two tabs have been.And after that a bend with a tong the string like an U (2x90 degrees) exaktly after the hole-with. And after that a pusch down the string in the two holes exaktly so high so the little finger on the battery-door go in. Test and try with the battery-door. And take a thinn tong and bend out the string to the left and to the right inside the kamera. Thats it. Work with care and slow and exaktly with mm-tholeranse. Good luck !!
SOURCE: broken battery compartment cover
The doors are about $20 on ebay. Heres a link for you:
http://cgi.ebay.com/KONICA-MINOLTA-Z6-BATTERY-DOOR-CAP-COVER-REPAIR-PART_W0QQitemZ170153738005QQihZ007QQcategoryZ64352QQrdZ1QQssPageNameZWD1VQQcmdZViewItem?_trksid=p1638.m118
SOURCE: CMOS Battery Clip Holder Broken. The CR2032 battery will not seat properly
You could purchase a CMOS battery card. they are usually about $10.00 and fit in a PCI Slot. II will .find you a supplier/
SOURCE: sentry s3877 battery compartment broke
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me [email protected].
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
SOURCE: FE-140 Battery compartment door broken
battery cover has small and minute parts so it breaks easily. getting a spare is difficult. only easy solution will be to take it to service center and fix it
Since many Sony headsets use the BP-HP550-11 battery pack, I assume your battery pack is the same. If not, I assume whatever battery pack your headset came with, it is some type of plastic holder that holds two batteries together. Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
