02 is a slow drain,
yopu can check your pump
take off the back wall and hoses,, have towels ready
you will loose water,,
inspect the inside of the pump and all hoses
Please read description carefully about error code
Logik Washing Machine Error 21: "E21" Error Code Definition: Washer has not drained in allotted / time washer not draining. How To Clear Error Code: -Check that filter is not blocked or kinked -Check drain hose is clear of any blockage or kinked -Check wires to drain pump -Check drain pump is not faulty -Check level sensor and switch -Check wires to level sensor
Oct 25, 2014 - In this video I'll be showing how to fix a washing machine with all the lights flashing and how to identify error codes or fault codes on Hotpoint, ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - Flashing lights Many modern washing machines display error codes if they detect a fault, but they don't all display a readable error code.
? 8:05
https://www.youtube.com/watch?v=P6WZNLO6wE4
Oct 22, 2014 - Uploaded by how-2-repair.com
Flashing Lights on Washing Machine How to Repair Hotpoint, Ariston, ... flashing like this.error faults are available at our website for all makes.
? 4:36
https://www.youtube.com/watch?v=S1L2N7srXKs
Mar 27, 2014 - Uploaded by DextersLab2013
Indesit Washing Machine Repair: Flickering Or Flashing Lights... Since making this video i have had to replace all of the remaining capacitors ...
www.fixya.com > Forum > Tags > error code 141 > Washing Machines
Bosch washing machines error code 141 related questions and answers. Ask your Bosch questions. Get free help from washing machine experts.
Washing Machines error code 141 questions and answers. Ask your error code 141 washing machine questions. Get free help, advice & support for popular ...
iFixitMy Zanussi Washing Machine hasn't been working properly for a while. then it stopped spinning and emptying, then wouldn't go through the programmes at all.
The Samsung washer error code reads 4E and means problem with the water supply. Please check the water pressure, also check for blocked or kinked water supply hose. You can learn more about all Samsung washing machine error codes in this helpful article: https://www.justfixed.co.uk/samsung-washing-machine-error-codes/
Error code E09 on a Hotpoint washing machine means software fault. This error is not easy to fix and you may need a professional help. You can find more information about Hotpoint error codes here: https://www.justfixed.co.uk/hotpoint-washing-machines-error-codes/
02 is a slow drain,
