Brookstone Pure-Ion UV Air Purifier Logo
Posted on Aug 08, 2009
Same prob here too.
No luck in finding a replacement uv bulb or any help from brookstone-any thoughts would be helpful. My unit is # AP-75 & the circular bulb is UVC 10w Thanks!
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 17, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
286
Points
If I cannot find the replacemnt part for the motor,we cannot remove the housing over the fan, looks like planned obsolesence to us! I will have 2 UV bulb replacements I just ordered from Brookstone for 20 each, will sell these to whomever would like them. KMWS
  • Joe Virga
    Joe Virga Dec 27, 2020
    Hello Kathy, do you still have the bulbs? If they are circular and part number UVC-254 10W for model no. AP-75, I am interested.
3 Related Answers
Anonymous
  • 619 Answers
  • Posted on Jan 04, 2008
SOURCE: Brookstone Pure-Ion UV Air
MOTOR ARE OPEN IF BURN OR BUSTED /NEED TO EPLACE //CHECK POWER SUPPLY.
Anonymous
  • Posted on Oct 15, 2008
SOURCE: brookstone pureion
call them they sell the bulb
Anonymous
  • Posted on Jun 14, 2010
SOURCE: how remove and clean filters from Brookstone pure ...
how to remove and clean filters for the Pureion UV air purifier?
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller.
Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device.
You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb."
If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller.
If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need.
Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
2answers
How do i clean my Brookstone Pure-Ion Uv Air Purifier
[PDF]Pure-IonĀ® Pro - Brookstone
www.brookstone.com/webassets/pdf/630285p_manual.pdf
BrookstonePure-IonĀ® Pro. Air .... Use this unit only for its intended use as described in thismanual . 4 . .... Position the unit so the cleaner air flows to your desired location .
Our Brookstone air purifier sounds like a bug zapper in spite of cleaning filter. It's less than a year old. What is the problem?
have you cleaned the connections where the filter connects . There is prob dust and dirt down inside the filter , keeping it from making a good connection. The zapping sound is from the electricty jumping the gap. A good cleaning of the inside should help. Try attaching a small hose to your vac to fit down inside the unit. give the electrical connections a good cleaning . If that dosen't work take unit apart and wipe down with alchol that you can buy at any drugstore
9helpful
How remove and clean filters from Brookstone pure ion uv air purifier?
How to troubleshoot a Pure Ion #AP-75 non-working
My ionair cleaner doesn't clean the air what so ever. All four filters are perfectly clean after running for over two months. All of them are properly inserted and seated as specified. No filter warnings turn on and the unit works in all other ways. There is an ongoing fire in the hills nearby and our house if full of hazy smoke.
13helpful
4answers
Lumipure AP-74 manual needed
hold in the power button for approx 5 seconds
1helpful
3helpful
2answers
Pure ion uv light does not turn on
Where can I get a replacement ultraviolet germicidal lamp? I have been to Brookstone store and on line without help. My unit is a Pure Ion.
Thank you.
Help! My air ilter quit!
I bought one a year ago and never thought it work well in cleaning the air. I get more dust on my counters than collects in the pure-ion. I recently got a letter from an attorney saying they are settling a class action suit on these purifiers because the are not effective. I called brookstone and they said they will refund my money because of the law suit. Good luck.
Top Brookstone Air Purifiers Experts
john h
ADMIN Andrew
ADMIN Andrew
Kardoc
Are you a Brookstone Air Purifier Expert? Answer questions, earn points and help others
