Televison & Video Logo
I have an AWA MHDV3245 tv.how do i get the codes for a universal remote
5 Related Answers
Anonymous
  • Posted on Sep 30, 2010
SOURCE: AWA LCD TV MSDV3203-F4 Universal Remote Code
Try using 12241
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on Jun 25, 2012
SOURCE: I have a cobolt universal remote and need the code
go to www. fitness.manualsonline.com or www. remotecodelist.com
God bless you
gopakumarg43
  • 76851 Answers
  • Posted on Jun 28, 2012
SOURCE: i have a AWA hd tv and i have a tevion 8in1universal remote i cant find the cod anywere some one help me
Try a code search procedure. If it do not help you
Visit this site for more details. The site name is (Electro-help). Just type in "electronicshelponline.blogspot" into the search box of your browser, and click search. You can see a site by this name. Pull up older posts there. Sometimes, ads related to each post might give you details about the availability of spare parts and price. It is a blogspot site, in English Language.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
gopakumarg43
  • 76851 Answers
  • Posted on Nov 17, 2015
SOURCE: I have an awa 32" tv which i have lost the remote to. Is it possible to tune tv without it (cant find an okay button) its a MHDV3245-03.. If i get a universal remote which is the best one. Tia
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some online sites too, which deals with electronic spare parts.
richie46
  • 12962 Answers
  • Posted on Mar 14, 2016
SOURCE: AWA 16" LCD TV
Need different universal remote
Testimonial: "Thought this might be an outcome. Any suggestions?"
2answers
I lost my awa tv remote controller and I have tried few universal remote but they are of no help. what can I do to resolve this problem because I haven't found awa tv remote no where my only hope is
Most universal remotes have a list of codes for each make. If yours isn't listed, try using a manual search on the remote. It should have an instruction on how to do a manual search. If this doesn't work, look on eBay. There are hundreds of different universal remotes. Im sure you will find one specific to your brand and model.
1helpful
4answers
Code for dick smith tv
I have read that AWA codes work. 039 worked for me. Try the below. If your universal remote uses 3 digit codes, drop the first zero.
AWA 0041 0066 0039 0187 0404 0481 0442 0067 0586 0246 636 0247 0138 0294 2015 1406 0208 0728
1helpful
AWA 16" LCD TV
1helpful
1helpful
Code UNIVERSAL tv Remote CHUNGHOP AWA TV Model LC-32G76
025.022,029. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
What is 3 digit Universal remote code for AWA W-3470AV LCD TV?
028,022,025.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
2answers
Top Universal Televison & Video Experts
vince
Jennifer Rock
Jennifer Rock
Are you an Universal Televison and Video Expert? Answer questions, earn points and help others
