Home Logo
B
Beatrice Jones Posted on Jun 17, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clock is chiming ithe incrrect time - Home
Peter Taylor
Level 2:
Habit-Forming:
New Friend:
  • Expert 119 Answers
  • Posted on Jun 18, 2019
Peter Taylor
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
119
Questions
0
Helped
114064
Points
317
Set to hour when chiming when finished set current time
1 Related Answer
Anonymous
  • Posted on Nov 10, 2010
SOURCE: timex westminster anniversary chime clock doesn't chime correct number
Take the batteries out from the base, where the chime mechanism is. Wait till it gets close (20 seconds till) to a specific hour time, like 8:00 or 9:00, replace the batteries for the chime mechanism. And then count the chimes at the hour. If they are correct, you are set. If they are incorrect, turn the time back 15 minutes before the hour and bring it right back and monitor the chimes again. Hopefully this should fix it. Please post the results.
How to get a sterling and noble chiming clock time set
To set the time on a Sterling and Noble chiming clock, please follow these steps:
Remove the clock from the wall or mantle and place it on a flat surface.
Locate the clock's time adjustment knob. This is usually located on the back of the clock and may be labeled "Time," "Adjust," or "Set."
Turn the knob clockwise or counterclockwise to set the correct time. Be sure to move the hands of the clock in the direction of the correct time.
If your clock has a chime feature, locate the chime adjustment knob. This may also be located on the back of the clock and may be labeled "Chime," "Strike," or "Silent."
Turn the chime adjustment knob to the "Silent" position if you do not want the clock to chime. If you want the clock to chime, turn the knob to the desired chime setting.
Once you have set the time and chime settings, replace the clock on the wall or mantle.
Note: It is important to set the time accurately and synchronize it with an accurate time source, such as an atomic clock, to ensure that the clock keeps accurate time. Additionally, it is recommended to consult the clock's user manual for specific instructions and troubleshooting tips.
Strausbourg manor quartz Westminster mantel clock. Why did it stop chiming?
Source: Wikipedia
The full hour chime is followed by one strike for the number of the hour by Big Ben (E3) (one strike for one o'clock, two strikes for two o'clock, and so on). ... The mechanism then plays two complete sets of five sequences for each complete hour.
Source: PortableFireplace
Learn how to fix a mantel clock that chimes at the wrong hour. This simple fix will repair a clock that chimes at the wrong time. This can commonly occur when your mantel clock is laid down on its back and the timing is offset.
1 Thing You Have to Understand First On most clocks you can turn the minute hand counter-clockwise but SOME clocks are not safe to be turned in that direction. For this reason, it's best to only turn your minute hand clockwise just to be safe.
The Simple Mantel Clock Adjustment The easiest way to adjust a mantel clock chime is to move the hour hand to the hour that the chime is striking. Make sure that the hour hand shaft is not too tight or else it will not turn. Most mantel clock hands are friction held. DO NOT BEND YOUR HOUR HAND, loosen the shaft if it will not turn freely.
Once you have synchronized the hour hand with the hourly chime, adjust the minute hand to set the clock to the correct time by moving it forward (clockwise) around the clock face. Allow the chime to strike at every quarter hour strike.
Mantel clock Chime Adjustment When your mantel clock chimes the wrong number of times, your chime is not synchronized time of the clock. To adjust your mantel clock chime, proceed with the following step:
ADJUSTING THE HOURLY CHIME
  1. When your mantel clock chimes, count the number of times it chimes. This is what time your hourly striker is set to.
  2. Move the hour hand to the hour indicated by the hourly chime (count the number of gongs at the hour).
  3. Reset the time using the minute hand to the correct hour and the chime should adjust along with the clock hands as well.
ADJUSTING THE QUARTER CHIME
On most mantel clocks, you can simple remove the minute hand which is friction fit. You have to apply pressure on the tube and it will loosen. Once removed, re-install the minute hand at the correct time. From there you can rotate the minute hand to reset the time.
Mar 17, 2021 • Home
How to match the time with the chimes on a Seth themes mantle clock. I have a Seth themes mantle clock. the time doesn't match the chime how do i fix it
when it chimes, spin the hands in clockwise direction to match what chimed.
https://www.collectorsweekly.com/clocks/seth-thomas
Jan 19, 2021 • Chime Home
How do I make my clock chime the correct number of times?
whenever the battery is weak the chime changes....whenever you change battery the clock chimes to the last time it chimed so...try setting your clock to next hour of chime n then move the hands of clock to next hour n your clock will chime accordingly.....
in this way waiting for chime to finish ...set to clock to present time ....waiting for it to chime every time the minute hand passes 12
Dec 09, 2015 • Home
My Gazo GF Clock won't chime on hour at all
When you are setting your clock, when you go pass the hour you have to let the clock chime completely, if you do not do this you can damage the time sequence..You have to reset the chime cable or belt...but anytime you set your clock when you get to hour let it chime completely before continuing on...Try also going around with hour hand onetime and let it chime, if it will chime at all, if not you can get a manual download online. Clocks like yours has websites and support who can help you...I think it just needs the chimes reset.
Dec 17, 2014 • Home
My clock chimes the correct amount of chimes on all hours except 7. At 7 it chimes 5 times
In a quartz movement clock, with a problem like this, the chime box (or whole movement) will need to be replaced. Timesavers.con carries a large selection of chiming quarts movements.
The chime of my Howard Miller mantle clock are not w/the actual hour set.How can I reset the chimes? Daylight Savings time has messed me up.
The next time it chimes multiple times turn the hour hand clockwise until it is pointing at the number of times it gonged. Next take off the dial nut off (make sure to put it in a plastic bag because they can be hard to replace) and turn the minute hand until it chimes signaling 15 minutes after. Now put the minute hand back on pointing to 3 o'clock and replace your dial nut and you are all set.
Fix Clock That Gongs Wrong
5helpful
3answers
Mantel Clock With Westminster/Whittington Chime: How to set the chime properly...
Pressing the red button advances the chime count by one. Continue to advanced the chime count until it matched the hour shown on the clock face.
3helpful
Problems with Howard Miller dual chime dual west and Beeth movement clock
If you manually set the time, the chimes will be off unless you wait for the chiming to finish before continuing to turn the hands.
Press the TEST button to get the correct number of chimes in synch with the actual time.
Top Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Home Expert? Answer questions, earn points and help others
