To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual
here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Hi musa ismail, I want to help you with your question, but I need more information from you. What software/package are you using?
