SOURCE: bosch 1200 classic express washing machine wont spin
Providing the machine isn't requiring major breakdown repair, the problem should be solved by emptying the machine and cleaning the drain pump. If this is obstructed the maching won't drain or spin as any bits left in clothes (paper clips, coins, nails, screws etc) wedge themselves into the (what I call a fly wheel) the pump impeller wheel at the back. If the fly wheel can't rotate the machine cannot pump or spin.
So.........turn off the washing machine before you fiddle about with it. Then, at the bottom right-hand side at the front of the machine there's a drop down door. Take this down and take it off. Then, lower the drain hose from its holder and pull the hose out of its housing. Be very careful if you're doing this while you have very hot water in the machine. To be safe, let the water cool before starting. Next take off the closing cap from the hose and empty the water from the machine. There are times when the water doesn't empty by this method so carefully open the door to the machine and bale it out. If the water does come out via the hose, have a suitably sized bucket at the ready as up to 20litres can be drained. Once you've done this, put back the closing cap of the drain hose and returned the drain hose to its holder, unscrew (anti clockwise) the petrol tank cap look-a-like placing a towel underneath as a little residual water will flow out. The pump impeller (fly wheel) must be able to rotate so clean out any residual fluff from the thread of the pump cap and pump housing before returning the pump cover and screwing tightly on. Put back the drop down flap and, hopefully, away you'll go again.
Hope this is of some help.
SOURCE: Bosch maxx classic washing machine doesn't clean clothes
There are a lot of things to consider when trying to solve this problem. Obviously a front loader washes differently than a top loader. Top loaders tend to using a washing motion that is good for stains but wear out your clothes fast. Front loaders typically use less water and wash more gently, but in some ways still do better than top loaders. Anyway, think about any other variables that go into the laundry equation. Consider the distance the machine is from your water heater. This machine will use MUCH less water to fill than your old one, and, you know how when you turn a faucet on hot it takes a minute for the hot water to actually get there? It's the same way with your machine. If there's a sink next your washer, you should always turn on the hot water on the faucet until it gets hot right before you start the machine. The same goes for dishwashers. If there's not a sink close you can easily turn up the temperature for all hot water on your water heater, although that will use more energy.
Consider what detergent you're using. If you're using high efficiency detergent (like Tide he) maybe you should switch to your old brand. If you're using your old brand of detergent, try getting a high efficiency detergent.
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: The water does not cutoff during rinse cycles
pressure chamber blocked with soap depists scale etc will need removing for service and cleaning partial strip down required.
