It is not playing CD. It is OK with DVD
HELLO
I have had this problem quite a few times and I will explain. In the laser pick-up of a DVD player it is, in fact, TWO lasers in one block. One plays CD/MP3 discs and other plays DVD's. It's more than likely that the CD laser has gone faulty which means you can only play DVD.
I have also had the reverse problem of it only plays CD's and not DVD. If you are not too upset that you cannot play CD's then just use it as a DVD player. If you want you can try to clean the lens of the laser block, but it's unlikely that will cure it.
You have two options. Use it as a DVD player only or get the optical block replaced, but it will cost you just as much as another DVD player if not more!
Hope this helps :-).
