My video doesn't record for long enough it only goes for 16 seconds do you have any clue on how 2 make it go for any longer???
Hi the only problem you can solve yourself for this is by deleting some of the files you have saved on the phone if you have loads of new ringtones that you have put on or loads of photos saved on phone this will take up all the memory and wont allow you to record for long.
What i did on my phone is delete all the standard ringtones you get with the phone and all the ringtones you never use i also deleted anything that came with the phone like screen savers and wall papers delete all the ones you dont use and will never use after doing this that should give you longer recording time.
The best thing to do is go through the phone and delete any messages, pictures, ringtones, screen savers, wallpapers anything that you dont need or use as keeping pictures and ringtones on your phone uses lots of the memory up.
After you delete all this you should have got a longer recording time let me know how you get on ok
SOURCE: my video does not record for long enough
you have to drop the resolution from the highest to atelast the middle or lowest resolution and then the option will apear when you access the video length menu to record for as long as your memory can hold. the only thing is that your device will not be able to send the video via cellular video mail when its length is too long. you also may be required to have a micro sd card installed in your device before thhe option will appear.
so recap, quality can stay fine, resolution needs to be reduced
pls rank this post,
thANKS
