Select Index Numbers here:
2 Asm, Jshaft Housing Head W
3 Q2 Pulley , 46"
4 Shaft, Splined Jacks
6 Nut, Pulley
7 Hub, Blade Adaptor
8 Q4 Blade 46" Mulcher
9 Washer, Bellevile(ard
10 Washer Hardened (ard
11 Nut Hex (ards)
12 Screw, 3/8, 16X1.25
24 Rod Belt Guide
25 Belt Cross Drive Ja
26 Belt Primary 46" J
34 Bracket Cover
35 Bracket, Pulley Cover
36 Qx Lburg# 094605E700 -INACTIVE-
37 Use Lburg# 093349 Zi -INACTIVE-
38 5/16, 18 Hexwdfllk Wh
39 Screw, 5/16, 18X.75HH
40 Cover, Pulley Right
41 Screw, 10, 16 .190X.62
72 711327
72-1 Wheel, Gauge
72-2 Bolt, .500X3.275HHSH3
72-3 Spacer, Slev .515X1.
72-4 Nut, 3/8, 16 Hxctrlkj
72-5 Qxcolor Code Require -INACTIVE-
79 Pin Detent Ring (DP5
80 Asm, Mulcher Plug 46
81 Bolt Carriage (ards
82 Nut, Wing (ards)
89 Zerk, Grease Fitting
