Question about Boating
Changing seal & bearing on prop shaft on mercury outboard 2015 150 hp
    Top Expert:
  • Boating Master
  • 29,179 Answers
SOURCE:
  • 9 Answers
SOURCE: 2006 450er atv
If you are replacing the bearing anyway, it doesn`t matter what happens to the bearing. Heat up the bearing over a flame getting it Very hot, the putting a shifting spanner os other spanner that can slide ofer the shaft but not the bearing, and hit the spanner with a hammer and that should move the bearing, Repeat until bearing is out.
*NOTE* Mark the shaft with something to show where the new bearing should be ( do not use a marking pen, it will burn off, use some thing metal but dont damage the shaft.)
Posted on Mar 12, 2009
  • 5692 Answers
SOURCE: 2001 mercury 25 hp will not go in reverse
Disconnect your shift and throttle cables, they may be reversed. See if the engine will shift now by hand. If it does not, then the problem was created when the shop benched the gear box and reinstalled it. Take it back even if it was last season. This kind of problem usually does not happen by itself.
Posted on Jun 25, 2009
  • 53 Answers
SOURCE: 2001 suzuki outboard water prop
water prop? if your talking about the Propeller that rotates to propel the boat. only replace it if fins are missing. Aluminum and stainless steel propellers can be rebuilt. If your talking about the water pump impeller. the answer is yes. its rubber and should be replaced seasonly
Posted on Nov 01, 2009
  • 14092 Answers
SOURCE: 2005 excursion 4x4 v10 front axle outboard axle
THE DRIVE SHAFT HAS TO BE REMOVE TO REPLACE THE PINION SEAL.DONT MATTER IF SEAL NOT LEAKING BUT SEAL NEED TO BE REPLACED TO KEEP OUT WATER DIRT OUT OF THE TRANSFER CASE TO KEEP FROM DAMAGING THE PINION BEARING.
Posted on May 02, 2011
goldbill
  • 184 Answers
SOURCE: mercury outboard 70 hp 1987 when in forward gear the prop turns one way when in neutrel spins both ways when in reverse the prop is locked both ways is my lower unit working property
mercury and others have a "sawtooth" cut for forward gear so the prop will rachet spin backward when dry tested, and a square clutch dog for reverse, which when it finally engages locks the prop in reverse. and will not spin in either direction.
So when you shift--- snap in in gear-- do not ease it in gear, as it will wear the dog out faster.
Posted on Sep 30, 2012
Mercury 150hp Optimax outboard
clean the connection on the back of the tachometer and on the sensor in the engine. If the engine remains at 2,000 rpm and won't go faster, you need a marine engineer with diagnostic equipment. That is a big engine on an 18 foot boat!
flooded cowl
Mercury Optimax loss of rpm
Injector, Coil, spark plug diagnostic
How to Diagnose Injector or Coil Fault on Mercury Optimax 150 HP Outboard...
mercury 150hp optimax outboard tachometer Google Search
Sep 01, 2018 | Boating
Tip
Outboard motors
Keep the gas in your outboard new/clean with new oil every 6 months..Keep your motor covered when not in use, Dirt dabbers (dobbers) will build nest under the hood and break loose and ruin your motor, ,,Change your water pump and thermostate every year when motor is used a lot.....Dont run stainless steel props on small hp motors ,when you hit a log it will bend your prop shaft costing big $$$ to replace..Ck your lower gear oil if water is noted ,replace lower seals...Dont buy used motors unless you run a compression ck....ck for water in gear case , Dont buy 4 strokes to heavy to slow to many parts AND are being replaced by fuel injection 2 strokes .... Dont buy FORCE motors not made by mercury no parts being made and or extink and pure junk . Etex best motors , .
on Mar 16, 2011 | Boating
I have a mercury 9.8 hp long shaft outboard serial #7144669 Do not know what year it is. Need a new prop. I live in Vancouver BC Canada Any Suggestions? Bill
props are available from any boat shop or on e-bay
if you prop problem is a failed rubber insert, they can be replaced by any accredited boat shop
what you need to know is the pitch of the prop as there are at least 3 different pitches depending on what you do with the boat, before you purchase on line
Jul 15, 2018 | Mercury Boating
What is the shaft length of my 1998 mercury tracker outboard Serial number OG676641
Measure from the cavitation plate (the one above the prop) to the u bend where the motor hangs on the transom. They are usually considered 15", 20", 25".
Nov 02, 2014 | Boating
Mercury outboard
The big nut that holds the gearbox together needs to be very tight
Sep 09, 2014 | Boating
How to remove propeller from 2007 40 hp mercury out board
REMOVE LOCKING TAB, UNBOLT NYLON LOCK NUT...DISCARD!
PROP SHOULD SLIDE OFF OUTPUT SHAFT...IF NOT PROP IS FROZEN.
IF IT A THRU HUB PROP, AND HAS A RUBBER SHOCK ABSORBING DEVICE...YOU CAN'T REALLY HEAT IT..YOU DEFINITELY DO NOT WANT TO BANG ON THE PROP(SHAFT AND BEARING DAMAGE)
SOMETIMES THE PROP HAS TO BE CUT OFF...REQUIRING A NEW PROP!
TIP: IF THIS IS THE CASE:*** ALWAYS COAT PROP SHAFT WITH ANTI-SEIZE COMPOUND WHEN INSTALL A PROP!!!!!
Jul 15, 2013 | Boating
Water pump
The water pump is a flexible impellor located in the top of the bottom section of the leg of the outboard. It is driven by the drive shaft to the prop that is spinning all the time the motor is running. You will find it behind or near the water inlet slots at the bottom of the leg
May 14, 2013 | Seloc Mercury Outboard Engine Repair...
Reverse jump & grin when put in reverse 90hp mercury outboard
This Can Be a Few Problems!
1- Check The Control Cables Are Set In The Neutral Position Correctly
Check And Try Again -If Not
2-Is The Control Box Moving The Lever Fully To Forward And Reverse Positions- If Yes
3- Remove Gearbox ,Remove Bearing carrier ,Remove Prop Shaft,
In The Front Of Prop Shaft There Should Be A Pin With Three Ball Bearings **(Will Give You The Problem You Are Having If Left Out) The Pin Should Not Be Flattened Or Badlly Worn ,
Replace If Worn
The Shift Cam Located Inside Gear Box Right At The Back Should Not Be Cracked Or Chipped ,You Can See It With A Torch Through The Middle Of Forward Gear ,Replace If Damaged.
Re Assemble And Test.
Mar 16, 2013 | Boating
I have a 2002 ox66 Yamaha 2 stroke 250 hp std rotation outboard. The propshaft snapped off. The fluid is clean and remaining shaft spins freely. Can i remove the two flange screws and carrier and pull out...
Prop shaft. You have to remove the bearing housing cap. reference number 70. Remove the bearing housing. reference number 60. The bearing housing will need to be pulled out buy using a puller. If it was in salt water it can be difficult. Pull the prop shaft and clutch dog assembly.
Nov 15, 2009 | Boating
I have a johnson outboard motor that drips oil from the prop.why is this ?,maybe a seal is blown?
Yes the prop shaft seal needs to be replaced.Do this sooner than later as water will get into the lower g/box.Sometimes they wear out or fishing line is a bad culprit.Its not a big job but it really needs to be done.The oil will also need replacing.Hope this helps
Sep 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
Top Boating Experts
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Tom Chichester
Are you a Boating Expert? Answer questions, earn points and help others
