SOURCE: How do you adjust cub cadet z-force 50 to go in
I'm not sure what you mean by going in faster but if that's the case pull your arms back quicker. If you want it to go faster in reverse then adjust the screws on the motion levers located kind of at the base of the levers. I hope this helps as the adjustment is pretty self explanatory once you find it. Their are numerous other adjustments you'll be learning as you go that will come in handy and make you enjoy your mower more. Such as mower disengagement, I hated that just because I wanted to back up one inch and the blades stop turning! Well, guess what. There's an adjustment that will disable this little feature located in about the same spot as the other adjustment. Search it and figure out all the neat little secrets and I hope you'll come to love yours as much as I do mine. I've had my Z Force 50 for over two years now and have mowed for 150 hours in that little time and I still love it. I just wish someone would come out with a cheaper after market blade because you will be going through them.
SOURCE: after adjusting deck 1042 cub cadet still cuttinglow right side
try checking to see if perhaps the blade is bent if not blade maybe the spindle or possibly the bearings are bad on the spindles causing them to not run true, also are all tires inflated properly good luck
SOURCE: Trying to put on mower deck belt for cub cadet
Visit this web site http://www.partstree.com/parts/
you can pull up your Cub
SOURCE: cub cadet belt keeps coming off the deck
Link to see video of the Fix for cubcadet deck belt coming off can be viewed here: http://www.youtube.com/watch?v=Pd4nYovcnvY
SOURCE: zero turn cub cadet mower, deck keeps clogging with grass
Did you recently replace the blades? If so I am guessing you put on mulching blades by mistake.
With the right blades, mine only clogs when either I cut to much grass at one time or the grass is too wet.
