Question about Radio Communications
Purchased HD stamped part #76000736A bluetooth helmet headset. will sena univerval helmet clamp kit 20S/20S EVO/30K work with this HD unit and still give out stero sound like the org. HD unit
SOURCE:
  • 4 Answers
SOURCE: I have an IPOD touch. I just bought d650 motorola
Unfortunately not all bluetooth headsets are compatible with the Ipod Touch. You should go the Apple's Website and see if that have a list of what bluetooth devices will work for them
Posted on Jul 17, 2009
SOURCE: LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
Posted on Oct 20, 2009
SOURCE: Motorola S805 headset worked fine with T60 laptop
Solution I found with the same devices is to properly par the devices.
Refer http://direct.motorola.com/ens/s805/QuickstartGuide.pdf
It basically states :
1.Ensure the headphones are turned off (L indicator light not blinking).
2.Press and hold L button. After about 6 seconds, the L indicator light becomes steadily lit.
3.Release the L button. The L indicator light remains steadily lit.
If the L indicator light is flashing or not steadily lit, repeat steps 1 through 3
Now on the T60:
Search for Bluetooth Devices as you would normally.
The T60 lists Bluetooth devices it finds.
Select Motorola S805.
Select OK or Yes to pair your headphones
with your phone.
Enter the passkey: 0000
Select OK.
When your headphones successfully pair
with your phone, the L indicator light
changes from steadily lit to rapidly flashing.
That's it next time you start a audio program on T60 output will be sent to Motorola Headphones
Posted on Jan 28, 2010
SOURCE: Can I use Bluetooth headset on Bluetooth enabled land-line phone?
See:http://www.testfreaks.com/blog/review/vtech-ls6245-cordless-phone-with-bluetooth/. Looks like you could at least with this one. I am also looking to do the same.
Posted on Apr 12, 2010
SOURCE: Trying to pair my HTC EVO to plantronics explorer
Had the same problem and called Plantronics. They reminded me about putting the earpiece in "Discovery Mode" by holding down the button when turning it on until it flashes blue/red. Then have the EVO scan for bluetooth devices. It found mine right away.
Posted on Oct 05, 2010
How to install the headset to my EVO 4g
To pair the Plantronics BackBeat 903 with an EVO 4G:
On the 903 headset:
With the headset powered off, press and hold the "Power/Pairing" button until the LED indicator flashes blue and red. This will put the 903 headset into pairing mode.
Use the iPod Touch menu to search for the headset and select 9xxBackBeat.
(If prompted, enter 0000 for the PIN code/passkey. Some devices also require you to accept the connection. Headset is paired when LED flashes blue.)
On the EVO 4G:
Turn the Bluetooth on from the Home screen, tap Menu, Settings, Wireless & Networks, Bluetooth.
Pair the EVO 4G by going to the Home screen, press Menu, Settings, Wireless & Networks, Bluetooth Settings, Scan for Devices. Follow the on screen prompts to pair the devices.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics Backbeat 903 Bluetooth...
How do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon howtoimage.aspx?id=12046 is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
May 23, 2011 | Jabra BT250 Consumer Headset
I have a bluetooth headset mounted in my motorcycle helmet and I can make a bluetooth connection between it and my nokia 6727 but now I got another Nokia 3727 and when I try to pair it with my helmet - I...
It is very posible that it is not connecting, reason being: compatibility. U should get a bluetooth headset that is compatible to both ur phones n pair it, that should solve ur problem. For example I can use any of BH320, BH200, BH600 on my Nokia 6120c n other bluetooth headsets I tried wont b accepted. U can try them n c. Good luck.
May 05, 2011 | Nokia 6120 classic Cellular Phone
Does this work with an evo shift 4g (sprint)
Jabt,
The Parrot supports the following bluetooth profiles: Headset Profile HSP 1.1, Hands-free Profile HFP 1.0, Object Push Profile OPP.
Your Evo should be able to pair using either the Headset profile or the Hands-free profile.
Thank you.
Mar 21, 2011 | Parrot MINIKIT Bluetooth Hands-Free Kit...
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
Jan 20, 2011 | Jabra Stone Bluetooth Headset
My tom tom rider cnt find my cardo scala headset even tho it is on, can you solve, thanx
i have the tom tom rider 2 its a great bit of kit but i disconnected the scala cardo headset for helmets so that i cold try a different bluetooth headset for use in a car and it didnt work i then tryed to recconect it to my tom tom and it cant find it when searching for it what do i do ? what have i done?
Aug 06, 2009 | Tomtom RIDER GPS Devices
Radio Communications Logo
37 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
